I think I arrived at a result
thank a lot for you help my friend.
i try update all
i try some format here
http://avisynth.nl/index.php/Avisynthplus_color_formats
RGB32 seem workCode:FFVideoSource("%source_file%", colorspace = "RGB32", \ cachefile = "%source_temp_file%.ffindex")
and i remove -pix_fmt yuva420p , i just dont use it at all!
But i have a strange repainting.
As if the engine kept an instance of each frame, but forgot to erases them.!
very strange
Results 31 to 35 of 35
Almost looks like image stacked in overlay, not clearing or displaying per frame
Did you try with one of the videos I uploaded ?
Upload your current output video -
yes you video do the same thing.
i think is issu for PIXIJS 4
is the engine i use.
It do this only with webm with alpha
https://github.com/pixijs/pixi.js
it a WebGL renderer for html -
I see you already posted on their issue tracker. The problem is on their end, since the video plays fine in browser (FF, chrome, not sure about others) with default HTML5. So just wait for their reply
What bit depth(s) can a video that has an alpha channel have?
By moonman239 in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2014, 16:46 -
spumux - Image transparency for menu.
By freevideo in forum Authoring (DVD)Replies: 8Last Post: 5th Jan 2014, 03:23 -
How to add transparency to a video clip?
By terrypin in forum Newbie / General discussionsReplies: 113Last Post: 13th Jul 2013, 08:33 -
Problem with the transparency of subtitles
By architectofpain in forum Authoring (DVD)Replies: 3Last Post: 14th Jun 2013, 22:55 -
Background transparency problem (DVD => .sup => .sub)
By Kaede in forum SubtitleReplies: 5Last Post: 4th Jan 2013, 16:34
