  1. Meteoric fall Solitary's Avatar
    Feb 2017
    Australia
    A few years ago I bought a Compro T300 Analog/Digital TV card, basically to record programs I wanted to watch later. Recently I decided to convert some VCR tapes two of my sisters sent me, burn them to disks so they can be watched on any ordinary DVD player complete with chapter menus and return them to my sisters.
    I plugged a Panasonic NV-HD620HD VCR into the card which is installed in a ten year old AMD Athlon mobo running on MS XP Pro via the composite plug and recorded away. Got both audio and video. So far, so good.
    The format of the resulting file:
    General
    Complete name               : C:\Documents ...\Capture\COMP_0728_0802.mpg
    Format                      : MPEG-PS
    File size                   : 70.0 MiB
    Duration                    : 1 min 27 s
    Overall bit rate mode       : Constant
    Overall bit rate            : 6 748 kb/s
    Video
    Format                      : MPEG Video
    Format version              : Version 2
    Format profile              : Main@Main
    Format settings, BVOP       : Yes
    Format settings, Matrix     : Default
    Format settings, GOP        : M=3, N=12
    Format settings, picture st : Frame
    Duration                    : 1 min 26 s
    Bit rate mode               : Constant
    Bit rate                    : 6 400 kb/s
    Width                       : 720 pixels
    Height                      : 576 pixels
    Display aspect ratio        : 4:3
    Frame rate                  : 25.000 FPS
    Standard                    : PAL
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Interlaced
    Scan order                  : Bottom Field First
    Compression mode            : Lossy
    Bits/(Pixel*Frame)          : 0.617
    Time code of first frame    : 00:00:00:00
    Time code source            : Group of pictures header
    GOP, Open/Closed            : Open
    GOP, Open/Closed of first f : Closed
    Stream size                 : 66.2 MiB (95%)
    Color primaries             : BT.601 PAL
    Transfer characteristics    : BT.470 System B, BT.470 System G
    Matrix coefficients         : BT.601
    Audio
    Format                      : MPEG Audio
    Format version              : Version 1
    Format profile              : Layer 2
    Mode                        : Dual mono
    Bit rate                    : 224 kb/s
    Channel(s)                  : 2 channels
    Sampling rate               : 48.0 kHz
    Stream size                 : 2.32 MiB (3%)
    I don't know what much of this means. First question: Would it be better to record in MPEG-4 format? According to the following list MPEG-4 is one of a boatload of other codecs available on my computer, and according to the brief Compro PDF manual it should show up among the options, but it does not. I wonder if I have missed a step during the installation of either the codecs or the TV card. If so, I don't know how to discover which one.
    Codec Reporting Utility Output Text
    Date and Time: 28-Jul-2017 08:21:37
    System Information
    Operating System  = Microsoft (R) Windows XP Professional (5.01.2600)
    CPU Descriptor    = AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
    CPU Clock Speed   = 2600 Mhz.
    Total Memory      = 2047 Mb.
    DirectX Version   = 9.0c
    WMI Version       = 2600.0000
    ACM Version       = 5.00.0
    Video Codecs
      AVI Decompressor
         FileVersion       = 6.05.2600.6333
         CompanyName       = Microsoft Corporation
         FileDescription   = DirectShow Runtime.
         InternalName      = Quartz.dll
         LegalCopyright    = Copyright (C) 1992-2001 Microsoft Corp.
         OriginalFileName  = Quartz.dll
         ProductName       =
         ProductVersion    = 6.05.2600.6333
      AVI Draw
         ProductName       =
      Cinepak Codec by Radius
         FileVersion       = 1.10.0.11
         CompanyName       = Radius Inc.
         FileDescription   = Cinepak® Codec
         InternalName      = iccvid
         LegalCopyright    = Copyright © 1992-1995 Radius Inc., All Rights Reserved
         OriginalFileName  = iccvid.drv
         ProductName       = Cinepak for Windows 32
         ProductVersion    = 1.10.0.0
      Compro Video Decoder
         FileVersion       = 1, 3, 3, 2
         CompanyName       = Compro Tech.
         FileDescription   = Compro Video Decoder Filter
         InternalName      = Compro Video Decoder
         LegalCopyright    = (c) 2003-2005 by Compro Tech.
         OriginalFileName  = CproDec.ax
         ProductName       = VideoMate
         ProductVersion    = 1, 3, 3, 0
      DirectVobSub (auto-loading version)
         FileVersion       = 3,0,0,211
         CompanyName       = xy-VSFilter Team
         FileDescription   = VobSub & TextSub filter for DirectShow/VirtualDub/Avisynth
         InternalName      = VSFilter
         LegalCopyright    = Copyright (C) 2001-2012 Yu Zhuohuang, Gabest et. al.
         OriginalFileName  = VSFilter.dll
         ProductName       = VSFilter
         ProductVersion    = 3,0,0,211
      DScaler Mpeg2 Video Decoder
         FileVersion       = 0, 0, 6, 0
         CompanyName       = DScaler Team
         FileDescription   = MpegVideo Module
         InternalName      = MpegVideo
         LegalCopyright    = Copyright 2005 Michel Lespinasse, Aaron Holtzman, Gabest, John Ad**** et al
         OriginalFileName  = MpegVideo.DLL
         ProductName       = MpegVideo Module
         ProductVersion    = 0, 0, 6, 0
      DV Splitter
         FileVersion       = 6.05.2600.5512
         InternalName      = Qdv.dll
         OriginalFileName  = Qdv.dll
         ProductName       =
         ProductVersion    = 6.05.2600.5512
      DV Video Decoder
         ProductName       =
      DV Video Encoder
         ProductName       =
      ffdshow Video Codec
         FileVersion       = 1.3.4533.0
         CompanyName       =
         FileDescription   = ffdshow VFW
         InternalName      = ff_vfw
         LegalCopyright    = Copyright © 2002-2013
         OriginalFileName  = ff_vfw.dll
         ProductName       = ffdshow VFW
         ProductVersion    = 1.3.4533.0
      ffdshow Video Decoder
         FileVersion       = 1.3.4534.0
         CompanyName       =
         FileDescription   = DirectShow and VFW video and audio decoding/encoding/processing filter
         InternalName      = ffdshow
         OriginalFileName  = ffdshow.ax
         ProductVersion    = 1.3.4534.0
      ffdshow video encoder
         CompanyName       =
      FM Screen Capture Codec
         FileVersion       = 1, 0, 0, 0
         CompanyName       = Fox Magic Software
         FileDescription   = FM Screen Capture Codec (VFW)
         InternalName      = fmvc
         LegalCopyright    = Copyright (C) 2005, Fox Magic Software
         OriginalFileName  = fmcodec.dll
         ProductName       = FM Screen Capture Codec (VFW)
         ProductVersion    = 1, 0, 0, 0
      Huffyuv v2.1.1 - CCESP Patch v0.2.5
         FileVersion       = 2.1.1 - CCESP Patch v0.2.5
         CompanyName       = Disappearing Inc.
         FileDescription   = Huffyuv lossless video codec
         InternalName      = Huffyuv
         LegalCopyright    = Copyright © 2000 Ben Rudiak-Gould.
         OriginalFileName  = huffyuv.dll
         ProductName       = Huffyuv
         ProductVersion    = 2.1.1
      Indeo® video 4.4 Decompression Filter
         FileVersion       = 4.51.16.03
         CompanyName       = Intel Corporation
         FileDescription   = Intel Indeo® Video 4.5
         InternalName      = ir41_32.ax
         LegalCopyright    = Copyright© Intel Corporation 1994-1998
         OriginalFileName  = ir41_32.ax
         ProductName       = Intel Indeo® Video 4.5
         ProductVersion    = 4.51.16.03
      Indeo® video 5.10
         FileVersion       = R.5.10.15.2.55
         FileDescription   = Intel Indeo® video 5.10
         InternalName      = ir50_32.dll
         LegalCopyright    = Copyright © 1994-1998 Intel Corp.
         OriginalFileName  = ir50_32.dll
         ProductName       = Intel Indeo® video 5.10
         ProductVersion    = R.5.10.15.2.55
      Indeo® video 5.10 Compression Filter
      Indeo® video 5.10 Decompression Filter
      Intel Indeo(R) Video R3.2
         FileVersion       = 3.24.0015.0003
         CompanyName       = Intel(R) Corporation
         FileDescription   =
         InternalName      = ir32_32.dll
         LegalCopyright    = Copyright Intel Corporation 1992-1995
         OriginalFileName  =
         ProductName       =
         ProductVersion    = Version 3.24.15.03
      Intel IYUV codec
         FileVersion       = 5.1.2600.5512
         FileDescription   = Microsoft H.263 ICM Driver
         InternalName      = msh263
         LegalCopyright    = Copyright © Intel Corp. and Microsoft Corporation 1995-1999
         OriginalFileName  = msh263.drv
         ProductName       = Windows® NetMeeting®
         ProductVersion    = 3.01
      Intel IYUV codec
      Lagarith Lossless Codec
         FileVersion       = 1.3.27
         CompanyName       =
         FileDescription   = Lagarith
         InternalName      = Lagarith
         LegalCopyright    = Copyright © 2011
         OriginalFileName  = lagarith.dll
         ProductName       = Lagarith
         ProductVersion    = 1.3.27
      LAV Video Decoder
         FileVersion       = 0.58.1
         CompanyName       = 1f0.de - Hendrik Leppkes
         FileDescription   = LAV Video Decoder - DirectShow Video Decoder
         InternalName      = LAVVideo.ax
         LegalCopyright    = Copyright (C) 2010-2013 Hendrik Leppkes
         OriginalFileName  = LAVVideo.ax
         ProductName       = LAV Video Decoder
         ProductVersion    = 0.58.1
      Microsoft H.261 Video Codec
         FileDescription   = Microsoft H.261 ICM Driver
         InternalName      = msh261
         OriginalFileName  = msh261.drv
      Microsoft H.263 Video Codec
      Microsoft MPEG-4 Video Decompressor
         FileVersion       = 8.00.00.4504
         FileDescription   = Microsoft MPEG-4 Video Decompressor
         InternalName      = mpg4ds32.ax
         LegalCopyright    = Copyright (C) Microsoft Corp. 1996 - 2001
         OriginalFileName  = mpg4ds32.ax
         ProductName       = Microsoft MPEG-4 Video Decompressor
         ProductVersion    = 8.00.00.4504
      Microsoft RLE
         FileVersion       = 5.1.2600.5908 (xpsp_sp3_gdr.091127-0541)
         FileDescription   = Microsoft RLE Compressor
         InternalName      = msrle32.dll
         LegalCopyright    = © Microsoft Corporation. All rights reserved.
         OriginalFileName  = msrle32.dll
         ProductName       = Microsoft® Windows® Operating System
         ProductVersion    = 5.1.2600.5908
      Microsoft Screen Video Decompressor
         FileVersion       = 8.00.00.4487
         FileDescription   = Microsoft Screen Video Decompressor
         InternalName      = mss1.ax
         LegalCopyright    = Copyright (C) Microsoft Corp. 1999 - 2001
         OriginalFileName  = mss1.ax
         ProductName       = Microsoft Screen Video Decompressor
         ProductVersion    = 8.00.00.4487
      Microsoft Video 1
         FileDescription   = Microsoft Video 1 Compressor
         InternalName      = msvidc32.dll
         OriginalFileName  = msvidc32.dll
      MJPEG Compressor
         ProductName       =
      MJPEG Decompressor
         ProductName       =
      MPC RealVideo Decoder
         FileVersion       = 1, 2, 1, 0
         CompanyName       = MPC-BE Team
         FileDescription   = RealMedia Splitter
         InternalName      = RealMedia Splitter
         LegalCopyright    = Copyright © 2002-2013 all contributors, see Authors.txt
         OriginalFileName  = RealMediaSplitter.ax
         ProductName       = RealMedia Splitter
         ProductVersion    = 1, 2, 1, 0
      MPEG Video Decoder
         ProductName       =
      Mpeg4 Decoder DMO
         FileVersion       = 9.00.00.4503
         FileDescription   = Corona Windows Media MPEG-4 Video Decoder
         InternalName      = mpg4dmod.dll
         OriginalFileName  = mpg4dmod.dll
         ProductName       = Microsoft® Windows Media Services
         ProductVersion    = 9.00.00.4503
      Mpeg43 Decoder DMO
         FileVersion       = 9.00.00.3250
         FileDescription   = Windows Media MPEG-4 Video Decoder
         ProductVersion    = 9.00.00.3250
      Mpeg4s Decoder DMO
         FileVersion       = 10.00.00.3911
         FileDescription   = Corona Windows Media MPEG-4 S Video Decoder
         InternalName      = mp4sdmod.dll
         OriginalFileName  = mp4sdmod.dll
         ProductVersion    = 10.00.00.3911
      MSScreen 9 encoder DMO
         FileVersion       = 10.00.00.4332
         FileDescription   = Corona Windows Media Screen Encoder
         InternalName      = wmsdmoe.dll
         OriginalFileName  = wmsdmoe.dll
         ProductVersion    = 10.00.00.4332
      QT Decompressor
         ProductName       =
      Ulead DVD Video decoder
         FileVersion       = 1, 0, 0, 30607
         CompanyName       = Ulead Systems, Inc.
         FileDescription   = DVD Video Decoder with DxVA Support
         InternalName      =
         LegalCopyright    = Copyright (C) 2003 Ulead Systems, Inc.
         OriginalFileName  =
         ProductName       = DVD Player
         ProductVersion    = 1, 0, 0, 30607
      USB Video Device
         FileVersion       = 5.3.2600.5512 (xpsp.080413-0845)
         FileDescription   = WDM Streaming ActiveMovie Proxy
         InternalName      = ksproxy.ax
         OriginalFileName  = ksproxy.ax
         ProductName       = Microsoft(R) Windows(R) Operating System
         ProductVersion    = 5.3.2600.5512
      VBI Surface Allocator
         FileDescription   = VBI Surface Allocator Filter
         InternalName      = VBISURF.AX
         OriginalFileName  = VBISURF.AX
      Video Port Manager
         ProductName       =
      VideoMate BDA Analog Capture
      Windows Media Video Decoder
         FileVersion       = 8.0.0.4000
         FileDescription   = Windows Media Video Decoder V8
         InternalName      = wmv8ds32.ax
         LegalCopyright    = Copyright (C) Microsoft Corp. 1996-2001
         OriginalFileName  = wmv8ds32.ax
         ProductName       = Windows Media Video Decoder V8
         ProductVersion    = 8.0.0.4000
         InternalName      = wmvds32.ax
         OriginalFileName  = wmvds32.ax
      WMV Screen decoder DMO
         FileDescription   = Windows Media Screen Decoder
         InternalName      = wmsdmod.dll
         OriginalFileName  = wmsdmod.dll
      WMVideo Advanced Decoder DMO
         FileDescription   = Windows Media Video 9 Decoder
         InternalName      = wmv9dmod.dll
         OriginalFileName  = wmv9dmod.dll
      WMVideo Advanced Encoder DMO
      WMVideo Decoder DMO
         InternalName      = wmvdmod.dll
         OriginalFileName  = wmvdmod.dll
      WMVideo9 Encoder DMO
         FileDescription   = Windows Media Video Encoder
         InternalName      = wmvdmoe2.dll
         OriginalFileName  = wmvdmoe2.dll
      x264vfw - H.264/MPEG-4 AVC codec
         FileVersion       = 43_2694bm_43159
         CompanyName       = x264vfw project
         FileDescription   = x264vfw - H.264/MPEG-4 AVC codec
         InternalName      = x264vfw
         LegalCopyright    = Copyright (C) 2003-2016 x264vfw project
         OriginalFileName  = x264vfw.dll
         ProductName       = x264vfw
         ProductVersion    = 43_2694bm_43159
    Audio Codecs
      AAC ACM Codec
         FileVersion       = 1, 9, 0, 0
         CompanyName       = fccHandler
         FileDescription   = AAC ACM Codec
         InternalName      = AACACM
         LegalCopyright    = Copyright © 2011-2012 by fccHandler
         OriginalFileName  = AACACM.acm
         ProductName       = AAC ACM Codec
         ProductVersion    = 1, 9, 0, 0
      AC-3 ACM Codec
         FileVersion       = 2, 2, 0, 0
         FileDescription   = AC-3 ACM Codec
         InternalName      = AC3ACM
         LegalCopyright    = Copyright © 2003-2012 by fccHandler
         OriginalFileName  = AC3ACM.acm
         ProductName       = AC-3 ACM Codec
         ProductVersion    = 2, 2, 0, 0
      AC-3 ACM Extensible
      AC3Filter
         FileVersion       = 2.6.0b
         CompanyName       =
         FileDescription   = ac3filter
         InternalName      = ac3filter
         LegalCopyright    = Copyright (c) 2002-2013 by Alexander Vigovsky
         OriginalFileName  = ac3filter.ax
         ProductName       = AC3Filter
         ProductVersion    = 2.6.0b
      ACELP.net
         FileVersion       = 3.02
         CompanyName       = Sipro Lab Telecom Inc.
         FileDescription   = Audio codec for MS ACM
         InternalName      = sl_anet.acm
         LegalCopyright    = Copyright © Sipro Lab Telecom Inc. 1998-99
         OriginalFileName  = sl_anet.acm
         ProductName       = ACELP.net Audio Codec
         ProductVersion    = 3.02
      ACELP.net Sipro Lab Audio Decoder
         FileVersion       = 1.40
         FileDescription   = ACELP.net Audio Decoder
         InternalName      = AcelpDec.ax
         LegalCopyright    = Copyright (C) 1997-99 Sipro Lab Telecom Inc.
         OriginalFileName  = AcelpDec.ax
         ProductName       = ACELP.net Audio Decoder
         ProductVersion    = 1.40
      ACM Wrapper
         ProductName       =
      CCITT A-Law
         FileVersion       = 5.1.2600.0 (xpclient.010817-1148)
         FileDescription   = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
         InternalName      = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
         OriginalFileName  = msg711.acm
         ProductVersion    = 5.1.2600.0
      CCITT u-Law
      Compro Audio Decoder
         FileVersion       = 1, 3, 0, 8
         FileDescription   = Compro Audio Deocder
         InternalName      = Compro Audio Decoder Filter
         LegalCopyright    = Copyright (C) 2003-2005 Compro Tech.
         OriginalFileName  = ComproADec.ax
         ProductVersion    = 1, 3, 0, 8
      CoreFLAC Audio Decoder
         FileVersion       = 0, 4, 0, 46
         CompanyName       = -
         FileDescription   = CoreFLAC Audio Decoder & Source DirectShow Filter
         InternalName      = CoreFLACDecoder
         LegalCopyright    = Copyright © 2003-2004 Christophe Paris & Jory Stone
         OriginalFileName  = CoreFLAC.ax
         ProductName       = CoreFLACDecoder
         ProductVersion    = 0, 4, 0, 46
      DSP Group TrueSpeech(TM)
         FileVersion       = 1.01
         CompanyName       = DSP GROUP, INC.
         FileDescription   = DSP Group TrueSpeech(TM) Audio Codec for MSACM V3.50
         InternalName      = tssoft32.acm
         LegalCopyright    = Copyright DSP Group, Inc. 1993-1996
         OriginalFileName  = tssoft32.acm
         ProductName       = DSP GROUP Windows NT(TM) TrueSpeech CODEC
         ProductVersion    = 1.01
      DTS
         CompanyName       =
         OriginalFileName  = ac3filter.acm
      ffdshow Audio Decoder
         CompanyName       =
      GSM 6.10
         FileDescription   = Microsoft GSM 6.10 Audio CODEC for MSACM
         InternalName      = Microsoft GSM 6.10 Audio CODEC for MSACM
         OriginalFileName  = msgsm32.acm
      IAC2
         FileVersion       = 2.05.53
         FileDescription   = Indeo® audio software
         InternalName      = iac25_32.ax
         LegalCopyright    = Copyright © Intel Corp. 1997
         OriginalFileName  = iac25_32.ax
         ProductName       = Indeo® audio software
         ProductVersion    = 2.05.53
      IMA ADPCM
         FileVersion       = 5.1.2600.5512 (xpsp.080413-0845)
         FileDescription   = IMA ADPCM CODEC for MSACM
         InternalName      = IMA ADPCM CODEC for MSACM
         OriginalFileName  = imaadp32.acm
         ProductVersion    = 5.1.2600.5512
      LAV Audio Decoder
         FileDescription   = LAV Audio Decoder - DirectShow Audio Decoder
         InternalName      = LAVAudio.ax
         OriginalFileName  = LAVAudio.ax
         ProductName       = LAV Audio Decoder
      Microsoft ADPCM
         FileDescription   = Microsoft ADPCM CODEC for MSACM
         InternalName      = Microsoft ADPCM CODEC for MSACM
         OriginalFileName  = msadp32.acm
      Microsoft G.723.1
         FileVersion       = 4.4.3400
         FileDescription   = Microsoft G.723.1 CODEC for MSACM
         InternalName      = msg723
         OriginalFileName  = msg723.acm
      MPC RealAudio Decoder
      MPEG Audio Decoder
         ProductName       =
      MPEG Layer-3
         FileVersion       = 1, 9, 0, 0306
         CompanyName       = Fraunhofer Institut Integrierte Schaltungen IIS
         FileDescription   = MPEG Layer-3 Audio Codec for MSACM
         InternalName      = l3codec.acm
         LegalCopyright    = Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
         OriginalFileName  = l3codec.acm
         ProductName       = MPEG Layer-3 Audio Codec for MSACM
      MPEG Layer-3 Decoder
         FileVersion       = 1, 6, 0, 52
         FileDescription   = MPEG Layer-3 Audio Decoder
         InternalName      = L3CODECX.AX
         LegalCopyright    = Copyright (C) 1997 Fraunhofer IIS
         OriginalFileName  = L3CODECX.AX
         ProductName       = MPEG Layer-3 Audio Codec for Microsoft DirectShow
         ProductVersion    = 1, 6, 0, 52
      PCM
      Realtek HD Audio Input
         InternalName      = QCap.dll
         OriginalFileName  = QCap.dll
         ProductName       =
      Realtek HD Digital input
         ProductName       =
      Ulead DVD Audio decoder
         FileDescription   = Audio Decoder
         InternalName      =
         OriginalFileName  =
         ProductName       = DVD Audio Decoder Filter
      Ulead DVD Audio decoder 2
         FileVersion       = 2, 0, 0, 29
         InternalName      =
         LegalCopyright    = Copyright (C) 2004 Ulead Systems, Inc.
         OriginalFileName  =
         ProductName       = DVD Audio Decoder Filter 2
         ProductVersion    = 2, 0, 0, 29
      Webcam 500
         ProductName       =
      Windows Media Audio Decoder
         FileDescription   = Windows Media Audio Decoder
         InternalName      = msadds32.ax
         LegalCopyright    = Copyright (C) Microsoft Corp. 1999-2001
         OriginalFileName  = msadds32.ax
         ProductName       = Windows Media Audio Decoder
      Windows Media Audio V1
         FileVersion       = 8.00.00.4502
         InternalName      = msaud32
         OriginalFileName  = msaud32
         ProductVersion    = 8.00.00.4502
      Windows Media Audio V2
      WM Speech Encoder DMO
         FileDescription   = Windows Media Audio 9 Voice Encoder
         InternalName      = wmspdmoe.dll
         OriginalFileName  = wmspdmoe.dll
      WMAPro over S/PDIF DMO
         InternalName      = wmadmod.dll
         OriginalFileName  = wmadmod.dll
      WMAudio Decoder DMO
      WMAudio Encoder DMO
         FileDescription   = Windows Media Audio Encoder/Transcoder
         InternalName      = wmadmoe2.dll
         OriginalFileName  = wmadmoe2.dll
      WMSpeech Decoder DMO
         FileVersion       = 10.00.00.4365
         FileDescription   = Windows Media Audio 9 Voice Decoder
         InternalName      = wmspdmod.dll
         OriginalFileName  = wmspdmod.dll
         ProductVersion    = 10.00.00.4365
    Broken Codecs
     [No codecs were found broken.]
    Another question concerns the lines of noise at the bottom, and from this point on I find myself in unknown territory. I have read that I could use some program to crop the picture around all four edges, then resize, but I really prefer to mask the lines at the bottom only in black. Can I do that in some program that has a graphical user interface? I've kind of gone off command line operations when Windows 3.1 became available.
    Two short notes:
    1: Is there a way to minimise the code boxes?
    2: I cannot afford to buy software. If it is not freeware it is out of my reach.
    Aug 2010
    San Francisco, California
    You converted to MPEG-2 video and MPEG-1 Layer 2 audio. These are suitable for DVD-Video disc. However, if you intend to do any processing, such as masking the head-switch noise at the bottom of the frame, you should initially convert to a lossless video codec such as HuffYUV and uncompressed PCM audio. Then perform your editing/processing, and finally convert to the codecs which are required for DVD-Video. Otherwise, you are doing two lossy encodings and quality will suffer.
    You can easily do capturing, editing and masking in VirtualDub.
    May 2014
    Memphis TN, US
    ......and if you now decide you want MPEG-4, which is another lossy final delivery format not designed for editing, then obviously you don't want DVD and should change the title of this thread. MPEG4 can't be used for DVD. You've also managed to choose a low quality obsolete audio format by using Layer 2. Meanwhile I'm still trying to figure out how you reversed the usual PAL VHS field order from top field first to bottom field first. Not that the fields won't work that way, it's just the reverse from the way most of the VHS world turns.
    - My sister Ann's brother
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Many of my PAL captures end up as Bottom Field First and look perfectly fine/normal. I cannot explain how they end up that way or which capture method/software was used at the time but I can say that the captures look perfectly fine and normal.
  5. Meteoric fall Solitary's Avatar
    Feb 2017
    Australia
    I'll download VirtualDub later tonight. Being new to all this, I'll probably need some pointers on how to configure it. My guess it will somehow have be told how to connect with my capture device, which is the Compro T300 TV card. Or will that happen automatically?
    I obviously don't need MPEG-4 then. I did nothing to reverse top and bottom fields. Nor do I even know what this means or what it does. That appears to be what the Compro setup does by default and I don't know if there is a way to change it.
    So, I guess there's nothing I really need to do about the reversal?
    Anyway, looks like I have a lot to learn. Meanwhile, thanks to all for your help so far.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    It has never been an issue for my captures
    But please be warned....many of my posts are intended to slow down the almost inevitable rush of condescending know-it-alls who tend to invade discussions like these.
    May 2014
    Memphis TN, US
    Don't be condescending, hech54. It's not like you.
  8. Member bendixG15's Avatar
    Aug 2004
    ..... condescending know-it-alls ... ??
    Where ??
