I've cleaned the video heads, erase head and control track head but it didn't fix the problem.
Results 1 to 10 of 10
Sounds like something in the circuitry. What happened to those other two you were working on ?
I still have the Mitsubishi HS-U748. The insides look similar but since I bought this from ebay, I rather return it.
I was thinking of changing the video heads.
It was working a couple of days ago. BTW, I'm not impressed with the TBC but the DNR is pretty good. -
I still have my HS-u748 also, but mine has something in the transport that's bad. In an earlier thread Baldrick
suggested the clutch mechanism. I could probably open it, but I'm not sure what to look for to be honest
Did they really sell the VCR with broken sound? Why change the video head?
I picked up a JVC s3911u at a garage sale last month. Working fine, but sounds like it needs a good lubrication. -
LOL, i don't know why. Just trial and error. I will just return it.
The VCR was working for a couple of days so I don't blame the seller. Just my bad luck. -
is the vcr / tv set on the right channel ?? if the vcr has more than one tv hookup then try a different hookup
Everything is setup correctly. I was trying to record via the VCR input and I see the video on the TV.
Sorry to hear that. Don't forget the linear audio as well as the hi-fi. I would have thought that if one of them failed
the other would still work, unless the problem is in the audio circuitry. Any caps bad on the board? -
I have the option of returning it, so I can't troubleshoot.
Here is a similar problem from 12volvids. https://youtu.be/-0P3Mzr3bNQ
In another video, he repaired a similar problem by simply cleaning the ribbon cables. https://www.youtube.com/watch?v=R9S2M0UQ-nw -
I reseated the video drum and control track ribbon cables and it's working now.
Which HDTV receiver will work with Mitsubishi HS-HD2000U?
By digicube in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2017, 11:49 -
Mitsubishi VCR - Can Only See Picture in Fast Forward or Rewind or Pause
By digicube in forum Capturing and VCRReplies: 2Last Post: 28th Jun 2017, 22:53 -
Anyone Help? SVHS to DVD Quality...Mitsubishi HS-HD2000U D-VHS , SVHS VCR
By lan2234 in forum RestorationReplies: 4Last Post: 21st May 2016, 04:41 -
Hauppage HD PVR 2 - Picture and audio in capture, but no sound out of TV
By Ryutso in forum Capturing and VCRReplies: 4Last Post: 1st Sep 2015, 16:54 -
VHS sound works, but no picture
By ceejerina in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2013, 18:33
