Hi All,
I just picked up an LG LRH-539 HDD DVD Recorder at a thrift store for 10 bucks without the remote. I've used simple universal remotes with other DVD recorders in the past and were able to navigate all the features successfully, but with this model my other remotes don't seem to be able to access all the necessary menus and settings to be able to do much with the unit outside of basic recording using the default options/settings. So now I'm tasked with trying to find a replacement remote for this guy and ordering through LG is going to cost me about $50
So my question then is, if I put that towards a nice Harmony remote that I can use with other devices and get more of my moneys worth am I going to have the same issues as with my other universals or are the Harmony's more capable of duplicating the originals capabilities?
Any help here is greatly appreciated.
Below is an image of the original remote and all it's various buttons lol
[Attachment 42427 - Click to enlarge]
Results 1 to 9 of 9
There is one in the US for $15.55
http://www.ebay.com/itm/LG-6711R1N192A-HDD-DVD-Recorder-System-Remote-Control-/3819351...AAAOSwImRYhmiK -
I had one years ago. You used to go to their website to download the device codes. Probably a good place to check.
In Uk. I have 650, purchased 2 years ago new around that price. Works fine. Almost certainly you will be able to download the codes for your recorder from Logitech site.
Just an update, got the Logitech 650 off of Kijiji (Canadian Craigslist) and it works perfectly...so glad I went with this then trying to find the original and it can do so much more!
If only it didn't need direct line of site with my Xbox One console (which is always behind a closed cabinet door) instead of working with the Kinect
Looking for Recommendation for Replacement DVD Recorder
By Novice20 in forum Newbie / General discussionsReplies: 17Last Post: 17th Jun 2015, 16:27 -
lg hdd/dvd recorder lrh-880-how to copy/record from disc/hard drive
By waynebyron7 in forum FeedbackReplies: 2Last Post: 5th Mar 2015, 13:33 -
Getting Remote Control Replacement for Mag DVD Recorder
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2014, 15:07 -
Use Insignia DVD/VHS Recorder Remote to Replace JVC DVD/VHS Recorder Remote
By rsatria in forum DVD & Blu-ray RecordersReplies: 7Last Post: 8th Feb 2014, 01:07 -
Considering a harmony remote...
By GLE3 in forum Newbie / General discussionsReplies: 4Last Post: 21st Feb 2013, 12:56
