OK, i'll try to explain how i tried to do it...step by step!
File/Project Wizard/Other/One VCD...--->NEXT
Select Source File - BlaBla.mpg...--->NEXT
Filter Setting - I don't want any, so i guess i just should leave it blank...--->NEXT
The MPG file is supposed to fit on a 80 min. Disc so i changed Audio Bitrate from original 224khz to 128khz. Average Video Bitrate would be than 1049 kbits...Estimated file size 771.21 MB.--->NEXT.
Output File: Whatever.mpg / Start Encoding Immediately / OK.
And then i get error msg: "Illegal floating decimal point calculator order"!
What have i done wrong?
Is there any other program that i can change bitrate with?
Thanx...and sorry for my bad english:-)
Your avi file has corrupt frames, Search on the forum or look in the tools/howtos on the left of this page for fixes
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Change bitrate of LPCM 5.1 ch ( audio file after demuxing )
By wisitch in forum AudioReplies: 3Last Post: 8th Apr 2010, 13:09 -
How do I change an .H264 TS video file's bitrate?
By bubbrubb in forum Video ConversionReplies: 1Last Post: 15th Feb 2010, 14:47 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
