I've read a lot on here, but this is my sole target.
The best card I ever used was a MSi Tv@nywhere, the non-plus version without a tuner and 10bit ADC. Obviously the captures were 8bit, but the S-video was the cleanest out of all the sub $300 devices... too bad it's PCi (without the 'e').
Any sub $400 pci-e suggestions? Or should I chance it with a pcie to pci riser adapter for the old MSi?
As far as internal capture cards for video transfer go I believe the older ATi all in wonder cards used to be a very good option, this limits your options to a legacy XP build however. It does appear that you are in the market for a newer alternative, most people doing this thing tend to go the external route for a capture device however I'm not sure of any major benefits / losses in either direction.
I've been using the StarTech USB3HDCAP for a while and is similar to the Black Magic Intensity Shuttle and is capable of a little bit more, it does in fact come in a PCi-e variant within your price range.
https://www.amazon.com/StarTech-com-HDMI-Video-Capture-Device/dp/B00U8KSSRY?th=1
I imagine it would be quite difficult to base your choice solely on the quality of the capture but when spending this much money on a capture device (unless it's notoriously bad) the difference in quality is usually marginal and will ultimately differ in features. -
Thank you to you both. I'll try the Startech or ATi and buy an adapter just to see. It's been well over a decade since I used the MSi (which was best of all sampled devices at doom9 back in the day, Haup was the worst).
Not that any of this will matter much as the tapes were all recorded with the onboard lamp and mic, so the quality can only have certain expectations. -
Like I said about the ATi card, they aren't made anymore so you will have to find a second hand one and the software that it uses only works on Windows XP. If you are going to go that route simply adapting the PCi to PCi-e wont work, you will need a dedicated machine to run the card. You might be able to use a Virtual Machine running XP, however having never owned one of the cards I can't really elaborate on what the current use scenario for it would be.
I have that card (both PCI and ISA variants), and about 12 others. The MSI has the cleanest video of them all. I haven't done this since about 2005, but I used to capture cartoons off of sat all day long (even had an iRC bot for others to schedule captures).
The VM would work, but first I'll soon discover if the riser adapter I bought is dangerous to my PC
Are there any mini pc's with PCI or PCI-e feature?
By vhelp in forum ComputerReplies: 12Last Post: 14th Mar 2017, 13:16 -
USB to PCI / PCI-e i/o adapter kits
By vhelp in forum ComputerReplies: 22Last Post: 7th Mar 2017, 08:59 -
Video capture USB vs PCI-e card
By videocapn00b in forum Capturing and VCRReplies: 6Last Post: 11th Apr 2016, 07:50 -
PCI SATA Adapter Issues
By bevills1 in forum ComputerReplies: 8Last Post: 10th Jul 2013, 15:38 -
PCI vs. USB capture device
By Faraz in forum Capturing and VCRReplies: 5Last Post: 28th Jul 2012, 23:09
