I am wishing to capture VHS tapes from my USB capture device.
- Intel Core i5-4210M
- NVIDIA GeForce GTX 850M
- Microsoft Windows 10 (x64)
I have extracted VirtualDub FilterMod 16 update 4 but there are five applications with the VirtualDub icon:
I presume I need to use Veedub64, is that correct?
- auxsetup (59 KB)
- vdub (9 KB)
- vdub64 (11 KB)
- Veedub64 (5.71 MB)
- VirtualDub (4.26 MB)
	VirtualDub.exe is the 32-bit version of VirtualDub, while Veedub64.exe is the 64-bit version. If you plan on adding a bunch of 3rd party filters, you are probably better off using the 32-bit version, as many filters were written as 32-bit only and do not have 64-bit counterparts. Some do, but many don't.
	vdub.exe & vdub64.exe are console wrappers, may be useful if you want to write some batch scripts.
 auxsetup.exe is probably useless.
	auxsetup.exe sets up the frameserver (Registery entries, etc.). You need to run it once if you ever plan to use the frameserver.
  Which filters recommended for VirtualDub(Filtermod)?By PabstBlueRibbon in forum EditingReplies: 3Last Post: 22nd Jul 2017, 12:00
  VirtualDub FilterMod (build 40035/release) ISSUE!By david.dgc in forum Video ConversionReplies: 7Last Post: 20th Jul 2017, 06:43
  Is the VirtualDub FilterMod better than VirtualDub?By ResetMaster in forum Video ConversionReplies: 26Last Post: 2nd Jul 2017, 15:08
  VDub FilterMod and Smart RenderingBy sambat in forum Video ConversionReplies: 5Last Post: 9th Jan 2017, 10:54
  Can't Get Virtualdub to Run on Wine in MavericksBy John97 in forum RestorationReplies: 0Last Post: 4th Nov 2014, 14:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
