  1. Hello my father has a good collection of old songs and some memorable moments in audio cassettes. We have Panasonic RX-CT65 System. Manual Please help me to convert those to MP3.
  2. That system doesn't have line out so you'll have to use the headphone output. Run a cable from the headphone output to the line-in input on your sound card. Use whatever software you want to record. Audacity (free) for example.
    The headphone output may be too "loud" for the line-in input on your sound card. If so, you'll to use a pair of attenuators:
    https://www.amazon.com/Harrison-Labs-Line-Level-Attenuator/dp/B0006N41AG/
    or a passive volume control:
    https://www.amazon.com/PAC-LC-1-Remote-Amplifier-Controller/dp/B0002J226O/
  3. ½ way to Rigel 7 cornemuse's Avatar
    Mar 2014
    Cyber Dystopia
    The unit has a volume control, I would assume it controls both speakers and headphones when plugged in, Start with low volume out and increase, keeping an eye on 'db's' in Audacity.
    I only ever had to buy a pre-amp cuz of low output, , , , (ie: turntable cartridge)
    -c-
    Yes, no, maybe, I don't know, Can you repeat the question?
    Aug 2010
    San Francisco, California
    You may find that cassettes recorded on a different machine sound dull or muffled when you play them back on the Panasonic. If so, you will need to adjust the azimuth of your playback head — if you can get to it on this deck.
  5. To complete all above - it will be good to provide load on headphone output - 2 resistors (1 on Left and 1 on Right channel) 32 - 100Ohm should do the job.
