Hi,
I have Ubuntu 17.04 running on a 24-core Xeon, I can get around 43fps doing X.265 transcodes with 4-5 copies of handbrake-cli running.
Does anyone know a way to easily split a mkv movie in to four, feed that in to handbrake-cli and then join the outputted mkv's together seamlessly?
I'm researching mkvmerge split functionality but it doesn't look like a foolproof way to seamlessly join and keep audio and subs in sync (to do with having to cut on key (IDR) frames).
Thanks for looking.
Cheers
Richard
	The IDR limitations you hint at exist with almost all programs. Exceptions are editors that re-encode on the cuts like SolveigMM Video Splitter (AFAIK).
 The "proper" solution would be to cut in the lossless domain. I.e. write a VapourSynth script with e.g. ffms2 source filter and trimming/slicing. Then pipe that into e.g. x265cli binary. Encode audio separately and as last step merge everything using mkvmerge. With HandBrake this would be difficult.
 Or you do use mkvtoolnix for splitting after all but make sure it's just at the IDR frames. Not having many or any IDR frames is mostly a problem with OpenGOP encodings. I don't know what sources you are working with.
  Encoding movie with x265 feasible?By -Habanero- in forum Video ConversionReplies: 1Last Post: 21st Mar 2015, 14:31
  Using VirtualDub and AviSynth to make a split/PiP movieBy WebMaximus in forum EditingReplies: 18Last Post: 22nd Jun 2013, 08:57
  MPEG Streamclip to join files but not transcode?By Corbey in forum Video ConversionReplies: 2Last Post: 12th Apr 2013, 13:18
  How can I split an mpg/avi into smaller movie files for editingBy tfoster in forum Newbie / General discussionsReplies: 6Last Post: 17th Mar 2013, 13:26
  3D movie is split screenBy littlealbert in forum Newbie / General discussionsReplies: 4Last Post: 12th Oct 2012, 13:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
