For some reason i'm not able to extract the subtitles from some mkv files
Well i can extract a subtitle file, but it's a broken file with no actual dialog in it just timings.
heres a link to one of the videos
https://openload.co/f/C-64TBAN7mc
these are not hardsubbed files, the subtitles can actually be turned on/off in VLC (though not mpc for some reason)
anyone got any ideas how to get it out?
well i'll try that later but even if it does work i have hundreds of files i need to extract.
and my mkvtoolnix is up to date. -
Use a batch tool like mkvcleaver
But the style extracted is slightly malformed in this file. Not sure why. But the text/timing are there -
open it up in notepad or some text editor - the text and timing are there but there are missing styles , malformed entries
ffmpeg / mkvtoolnix extract it the same way . Not sure why -
gMKVExtractGUI has a batch mode https://www.videohelp.com/software/gMKVExtractGUI
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Check again. With latest mkvtoolnix there should be no problem. (bug was fixed in 10.0.0)
As poisondeathray said these ASS subtitles are malformed (if you assume de-facto standard to be Aegisub style).
Workaround: use a libass based subtitle renderer. For example the one in VLC or mpv. For MPC-HC you can use AssFilterMod.
Fix: extract subtitles using up-to-date mkvtoolnix, fix like explained here, then remux. -
hmm well i had version 13 and it wasn't working
updated to 14 and it does now.
thanks
extract all subtitles from a mkv
By Valit in forum SubtitleReplies: 4Last Post: 10th Jan 2016, 19:10 -
Extract vobsub from mkv
By anime12345 in forum Video ConversionReplies: 1Last Post: 14th Aug 2015, 11:39 -
Extract audio from mkv
By tun.tin in forum AudioReplies: 4Last Post: 17th May 2015, 18:07 -
Extract SRT From MKV
By Valentin in forum MacReplies: 4Last Post: 12th Sep 2014, 21:14 -
I cant extract the whole subtitles from an mkv
By ErdeZGZ in forum SubtitleReplies: 18Last Post: 13th Aug 2014, 18:11
