    Oct 2014
    Between a rock and a hard place
    I installed the software this morning and had an error related to skins at the end of installation, when trying to launch the application for the first time. Software reported it would use default skins. What I have now is an application missing all of its distinct pictographic buttons, which are replaced with what appears to be "rainbow-colored film clips."
    Is the new version buggy? Is there any way to fix this?
  2. Member DB83's Avatar
    Jul 2007
    Mr_C_ may see you post (even if it is in the wrong forum)
    More likely to see it though in the support thread
    https://forum.videohelp.com/threads/277852-AVStoDVD-Support-Thread
    Oct 2014
    OK, thanks.
