Hi
Any idea where I can obtain this....?
Couldn’t locate decompressor for format ‘FMP4’ (unknown)
VirtualDub requires a video for Windows(VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player are not suitable.
ffdshow should have a decoder for it.
Alternatively, use ffmpeg input plugin for VirtualDub or VirtualDub FilterMod which has such plugins integrated.Last edited by sneaker; 22nd Jul 2017 at 06:30.
Unfortunately no expert whatsoever and already way out of my depth so downloaded both but it's still showing the same message as above. I'm using Build 37425 if it's any help....
Thanks -
The newest VirtualDub FilterMod can be found here. Unpack, start VirtualDub.exe and Fiile->Open and select your video file. If you receive the same error try again File->Open but this time at the bottom of the file open dialog select "FFMpeg (all formats)" before opening the file.
Thanks having a big problem at the moment with ultra slow downloads but will keep trying....
The reason VirtualDub (the official version) wasn't working to begin with is it requires you to have an appropriate decoder installed and if it can't find one it'll complain.
ffdshow is a bunch of decoders rolled into one (for want of a better description) so installing ffdshow allows VirtualDub to decode all the common formats.
VirtualDub FilterMod is a modified version that comes with it's own decoders.
There's also an Input plugin for the official VirtualDub called FFMpeg Input Plugin that offers similar functionality.
The official VirtualDub can't open many file types and is generally used with AVIs, whereas with the FFMpeg Input Plugin installed it can open all the common types such as MP4 or MKV etc.
VirtualDub FilterMod has similar abilities.
There's no need to keep updating the programs so they'll keep opening a particular file. Once the correct decoder is installed (if required) VirtualDub will be able to open it forever, but it doesn't hurt to upgrade occasionally if you plan on using it regularly. Bug fixes or additional functionality etc. -
Ah great thank you, all a little over my head but at least no need to worry about it any more....
.AVI header: where is the flag that tell to the decompress if interlaced?
By marcorocchini in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2016, 17:09 -
Decompress flac 5.1 24bit 48 khz to wav
By anana in forum AudioReplies: 2Last Post: 5th Mar 2015, 08:34 -
Help Needed! No audio decompressor could be found
By Aniahlator in forum EditingReplies: 12Last Post: 15th Sep 2014, 04:03 -
Virtual Dub: Unable to decompress avc1 file format
By s_joy09 in forum Video ConversionReplies: 29Last Post: 8th Oct 2013, 09:07 -
Decompress ALAC file
By Foxman50 in forum AudioReplies: 29Last Post: 23rd Jul 2013, 09:23
