Hi all
So there's a video on YouTube that I set via it's player to play at 1.5x faster. I downloaded it using 4K Video Downloader and now just want to mimic that same speed change in the saved .mkv file itself.
I'm not real sure how to do this?
I've tried setting the FPS for the video (in MKVToolnix) at 48fps (MediaInfo says the video portion of it is at 32.420 FPS) (32/2 = 16. 32 Bit + 16 = 48), but then the video seemed too fast, and the audio was still the same slow speed, and I'm also not sure what the delay speed change in milliseconds would be to match?
Maybe I'm just going about this in too complicated of a way?
Any help appreciated
Instead of the "fps" field try setting "Stretch by" to "2/3" for both audio and video. At least video should work good that way. With audio it may or may not work good depending on your player. Proper way would be to re-encode audio with a speedup using e.g. ffmpeg or SoX and then mux back.
Can you link to the Youtube video? 32.420 fps is a strange value. -
Hi Sneaker
Thanks for your help. I haven't had the chance to try your advice yet, but just to answer your question, this is the video I'm having trouble with.
Wi-Fi speed
By kyrcy in forum ComputerReplies: 6Last Post: 2nd Mar 2017, 12:10 -
Mkv merge very low speed
By ben45 in forum Newbie / General discussionsReplies: 5Last Post: 4th Apr 2016, 04:45 -
Changing playing speed of MKV file
By djdj in forum EditingReplies: 7Last Post: 14th Apr 2015, 19:27 -
BD-RE problem with speed
By asiafan in forum Authoring (Blu-ray)Replies: 0Last Post: 13th Oct 2014, 15:15 -
tubeDigger 4.4.1 converted mp4 plays at fast speed not normal speed!
By spiderMan007 in forum Video ConversionReplies: 8Last Post: 14th Jun 2013, 02:24
