hello, everyone.. regular user of the info and software in this site but joining the forum for the first time to ask a very specific question.
I have a video that are improperly encoded at source and the playback stop-start every 5 to 10 seconds. (no issue with my software/hardware setup as I can play back all videos easily) . Is there a software editor or plugins/filters that can analyse and reencode the video that would remove all the intermittent stop-start section ? technically, it should be possible but couldnt find much info on whether such software, app plugins exist ... anyone can provide more info or point me to the right direction to rectify this ?
heres the media info extracted using MPC
General
Format : AVI
File size : 4.22 MiB
Duration : 7h 10mn
Overall bit rate : 1 370 bps
Video
Format : AVC
Format profile : Baseline@L3
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : H264
Duration : 1mn 32s
Bit rate : 246 Kbps
Width : 480 pixels
Height : 360 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.047
Stream size : 2.72 MiB (64%)
Audio
Format : AAC
Format profile : LC
Codec ID : FF
Duration : 7h 10mn
Source duration : 1mn 9s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 1.06 MiB (25%)
Alignment : Split accross interleaves
Interleave, duration : 23 ms (0.70 video frame)
thanks for your prompt reply -
General
Format : AVI
Duration : 7h 10mn
Video
Format : AVC
Codec ID : H264
Duration : 1mn 32s
Bit rate : 246 Kbps
Width : 480 pixels
Height : 360 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : FF
Duration : 7h 10mn
Bit rate : 128 Kbps
Open-source software to record video from webcam?
By kg123 in forum ComputerReplies: 30Last Post: 22nd Nov 2016, 20:15 -
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
Automatically Split MP4 File Based on Start/Stop of Source Video Camera
By thomaspier in forum EditingReplies: 5Last Post: 28th May 2015, 14:49 -
How to fix shaky video in APE 12 or other software ?
By AAC in forum EditingReplies: 1Last Post: 8th Sep 2014, 21:13 -
Software real-time video mixing with a webcam source?
By Brad in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2013, 22:02
