Hi all, i just bought new speakers (Logitech z906) and hooked them up via analog connectors (as i always do).
Everything working fine but i figured out that in order for them to decode DTS properly i need to setup a digital connection.
So i googled and i am overwhelmed by so many different terminologies. Spdif/coaxial/optical that my head literally became swinging for a sec. Truth be told i never setup a home theater system myself and i don't need anything fancy, i am just trying to figure out how to connect the speakers to my sound card via digital connection, i.e. what kind of cable i really need to buy.
My sound card is Creative X-Fi Titanium (SB0880) and speakers are Logitech Z906. I even googled some visual pics but yeah i am still too dumb to figure out what kind of cable i really need. If some audiophiles can explain a bit or just lemme know which cable to order then i would be really thankful.
Here have a look at following two diagrams to know what connectors my card and speakers got:
Soundcard:
http://support.creative.com/kb/ShowArticle.aspx?sid=68106
Speakers:
http://support.logitech.com/en_ch/article/23022?product=a0qi00000069uqEAAQ
Both your sound card and speakers have optical SPDIF connectors. You just need an optical cable like this:
https://www.amazon.com/AmazonBasics-Digital-Optical-Audio-Toslink/dp/B00NH11H38/
But you should be able to install a DTS decoder for use with your current analog setup. -
Thanks jagabo for the valuable input. I am gonna go out to my nearest retail store tommorow and pick up the cable. It sucks logitech didn't bother to include a $5 cable in $300+ speaker set.
As comparison, i recently bought an Asus 4K monitor and it came with a DisplayPort 1.2 cable & 2x HDMI 2.0 cable (Yes 2 HDMI 2.0 cables). Gotta love Asus. -
Update: So i picked up a cheap ~$5 optical audio cable and hooked it to my amp and i can immediately notice the sound quality is much MUCH inferior to analog.
Is it because of the cheap cable? The store i went to had a good branded energizer optical cable for $35 and the cheap $5 which i bought. Is the price difference make much difference? I can't really order online since i live in a 3rd world Asian country.
Also on my logitech display, the DTS decode led never lights up even if i am playing a source which has DD or DTS surround. In windows SPDIF output format i only have the option to output in 2 channel. Its currently set to 2 channel, 24bit, 48000 Hz
EDIT: A little progres. I can output surround if i hook the optical out of my motherboard rather then soundcard. It appears my old X-Fi Titanium only does 2 channel over spdif. However the sound quality is still atleast 10 times better over analog and the issue is out of these two i think:
1. Either the optical audio cable i bought is total trash which is causing poor quality.
2. The DAC of my soundcard is FAR better then what my amp can output. Because as far as i know, for analog signal your soundcard's dac does the digital-->analog conversion and then passes the signal to amp. In digital format, the signal is passed as is to the amp which does the rest.Last edited by sohaibrazzaq; 22nd Jul 2017 at 05:47.
In what way is the sound inferior with the optical cable? In any case, the cable is almost certainly not the problem. Errors in digital audio transmissions are not subtle -- you will hear loud clicks, pops, screeches, etc. I also doubt the DAC is the issue. Digital to analog audio conversion is pretty trivial. It's more likely the X-Fi was applying some kind of processing that you liked.
Like at same level the sound on analog is MUCH more loud and clear, it has more range in lows and highs.
I dunno either its that or that my ears have over 10 years of experience with listening sounds coming with few creative effects like X-Fi crystallizer etc in the mix but even if i disable all of the creative enhancements the sound coming out of speakers is much more loud and crisp. -
Loudness is not quality. Crispness is probably just an equalization curve being applied by the X-Fi. Passing digital audio from the source to the speakers bypasses all that processing. And crispness also doesn't equate to quality. A professionally mastered source and good speakers don't need to have the highs boosted -- except maybe to make up for room acoustics.
In any case, a bad optical cable could not cause those problems.
5.1 audio on 2 speakers PC
By Freodon in forum AudioReplies: 3Last Post: 10th Dec 2015, 19:27 -
PC speakers & TV Speakers At The Same Time
By TheRandomOne in forum AudioReplies: 0Last Post: 6th Oct 2015, 12:20 -
Recording 4 channels with 1 soundcard using SoX
By santi in forum AudioReplies: 0Last Post: 5th Feb 2014, 09:07 -
Need help in connecting speakers to my TV.
By v1v14n in forum AudioReplies: 16Last Post: 14th Dec 2012, 04:59 -
XLR to USB adapter VS capturing via PC soundcard
By julitomg in forum AudioReplies: 2Last Post: 10th Dec 2012, 14:03
