Hi ***
where concatList.txt is:Code:v:\automazioneclip\core\ffmpeg64bit332.exe -y -threads 12 -y -f concat -safe 0 -i concatList.txt -filter_complex "[0:1] [0:2] amerge" -vcodec copy -c:a pcm_s24le -aspect 16:9 concatHD.mov
this MXF's are xdcam hd 4:2:2 video files.Code:file 'V:\recanati\C0003.MXF' file 'V:\recanati\C0005.MXF' file 'V:\recanati\C0008.MXF' file 'V:\recanati\C0010.MXF' file 'V:\recanati\C0013.MXF' file 'V:\recanati\C0015.MXF' file 'V:\recanati\C0016.MXF' file 'V:\recanati\C0017.MXF' file 'V:\recanati\C0018.MXF' file 'V:\recanati\C0019.MXF' file 'V:\recanati\C0020.MXF' file 'V:\recanati\C0021.MXF' file 'V:\recanati\C0022.MXF' ... ... file 'V:\recanati\C0116.MXF'
At the beginning of encoding speed is good (300 fps, 11x) but after some seconds the speed go down to 95 fps and more down
[Attachment 42383 - Click to enlarge]
Why? thanks
Probably because your disk cache is full so you're reduced to the actual write speed and seek time of the drive(s).
set destination to different physical drive and compare results - almost sure that jagabo is right.
[Attachment 42387 - Click to enlarge]
I have try on a different disk drive, same falling down but from 16x to --> 9x (instead of 11x-->3x).
Is not costant, but maybe is normal
thanks -
Your video is about 52000 kbps. Mulitply by 9.5x, then divide by 8 to get KB/s and you get about 60000 KB/s, or 60 MB/s. That's typical for continuous writing to a hard drive (depending on the interface, the size of the drive, and what part is being written to).
how do i use ffmpeg to see if a video is interlaced or progressive ??
By oduodui in forum EditingReplies: 3Last Post: 30th Jun 2015, 07:33 -
FFMPEG: can crop 32 lines using vcodec copy?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 26th Feb 2015, 15:39 -
Convert MPEG2 to progressive and real fps, ffmpeg warnings, etc
By Wader8 in forum Newbie / General discussionsReplies: 6Last Post: 1st Sep 2014, 17:11 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53 -
FFDSHOW: can I do in ffdshow what I do with "-vcodec copy" in ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 20th Oct 2013, 17:25
