I have an HP 4540s. The DVD burner failed and I replaced it with a MATSHITA BD-MLT UJ265
It will not copy every BluRay I put in it. I chalk this up to bad disks.
It burns all type of blank BluRays and DVDs [ RW, BD-R, BDXL, BD-R DL, BD-RE ] fine.
The bug is when I put a disk in the slot it kicks it back out.
I have found a work around. If the disk is in when I boot up it will work fine.
Sometimes after inserting a number of disks it will stop. The burner has no firmware updates so?
	Did you try Uninstalling the drive and reinstalling ??
 Also check for a driver update.
	Yes I uninstalled the drive, but there are no updates. There is no BOIS setting to change either. I think I will just have to stick with the boot trick
  Computer won't stay asleep, can't figure outBy sdsumike619 in forum ComputerReplies: 3Last Post: 4th Mar 2017, 12:54
  DVD Recorder drive will NOT stay closedBy seskanda in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Feb 2015, 00:31
  Does Ripping damage the DVD? (the disk, not the drive)By bachelor in forum DVD RippingReplies: 14Last Post: 26th Jan 2015, 18:02
  Panasonic DMR E95H Hard drive disk swapBy madsharpei in forum DVD & Blu-ray RecordersReplies: 4Last Post: 4th Feb 2014, 17:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
