I have owned this model scanner for few years now, over time i started getting dust on the underside of the glass for some reason, so i pulled the top off and cleaned the internal glass and the glass only , i didn't touch anything else....... the problem now is, no matter what i scan, what settings i use , everything is blurred...... i have nearly used every dpi range but everything is blurred......i think if i took it away to get fixed they will charge me the same price as a new one... any help? do you think the light bulb is damaged? the quality of the scan is still great, no marks or lines but everything is blurred.. thanks
my guess would be you didn't get it back together properly. iirc that one has snap together clips that need a fair bit of force to get all the way closed.
How to clean the inside of the glass of the Epson Perfection V200 Scanner
https://youtu.be/WUYiT09R4PA
I could not find how to clean the V300
Blurred frames on video
By LuckyRed93 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Apr 2016, 03:25 -
Blurred Blu-Ray video
By maverickluke in forum Authoring (Blu-ray)Replies: 61Last Post: 7th Dec 2014, 15:16 -
Sony AVCDH Blurred Video
By diegomenezes in forum Video ConversionReplies: 4Last Post: 10th Jun 2014, 13:08 -
Epson Stylus SX235W Wireless... Scanner won't work? Error...
By UmmAddan in forum ComputerReplies: 17Last Post: 4th Jan 2014, 18:00 -
multiAVCHD sometimes picture is blurred
By Hrki in forum Authoring (Blu-ray)Replies: 0Last Post: 5th Aug 2012, 08:44
