I am running on a Windows machine.
I need to join several mp4 files that my camcorder split into 4GB files (though I don't know why since my SDcard is formatted in exFAT). No need for any transitions in-between or re-encoding or anything like that, they are one continious video and I just want to combine the files themselves into a single one, there should be no gaps from when my camcorder split them.
Would it be better to use mp4box or ffmpeg for this? Or is there another better solution?
I tried using mp4box but I can't figure out the proper syntax, everything I Google uses a different one. Namely, it's not clear if you should use -add for the first file and -cat for all the others, or just use -cat for all of the files.
E.G.:
MP4Box -add file1.mp4 -cat file2.mp4 -cat file3.mp4 -cat file4.mp4 -new output.mp4
vs
MP4Box -cat file1.mp4 -cat file2.mp4 -cat file3.mp4 -cat file4.mp4 -new output.mp4
Is there even a difference between what would happen if I used one or the other?
Results 1 to 1 of 1
Right way to join two different video files using ffmpeg?
By yetanotherlogin in forum EditingReplies: 15Last Post: 25th Jun 2021, 03:25 -
Join MP4 files
By Casterina in forum EditingReplies: 5Last Post: 21st Sep 2016, 11:06 -
Anyone know how to join mp4 clips by My MP4Box GUI ?
By kwanami in forum EditingReplies: 2Last Post: 26th May 2016, 04:33 -
[SOLVED] How to join MP4 files where some have more than one audio stream?
By yetanotherlogin in forum EditingReplies: 3Last Post: 19th Nov 2015, 05:32 -
Plain English Guide to MP4Box and Repacking MKV-MP4, MP4-MP4 (M4V).
By raregrit in forum Video ConversionReplies: 3Last Post: 8th Jul 2013, 13:52
