What would be the best quality between bluray to DVD5 and DVD9 to DVD5?
I tried BD50 to x265 then to DVD5 and quality is pretty bad so are the colors.
I am pretty sure DVD9 to DVD5 is still the best option but I still wish there is a good way to set a BD25 or BD50 into DVD5 for good quality.
Results 1 to 11 of 11
What was the point of that, to use an extra and quality degrading step.
You have to take into account the change in the colorimetry from hi-def to std-def. Did you say how you performed this conversion? Of course any DVD is going to look like crap compared to a good Blu-Ray but maybe try AvsToDVD....so are the colors -
Gracias
but I wanna know what people think about let's say what's better in term of quality image for original Logan Bluray movie to Dvd5 versus original Logan Dvd movie to dvd 5... maybe it's more clear like this. -
- My sister Ann's brother
You can convert Blu-ray to DVD5 in BD Rebuilder. You'll need to change the default output. Or you can do it in AVStoDVD, which isn't hard to do if the main movie is in one M2TS file. Use the HC encoder in a two pass mode.
Quality is going to suffer no matter what. You're reducing resolution and using lower bitrate. -
Actually, what is your question? The DVD Video Specification calls for using the MPEG-2 codec. AVC (used in Blu-ray) is a more efficient encoder. Given the same file size, the AVC encoded video will be superior to the MPEG-2 encoded video.
Is your question "What source to start with?" The answer is the Blu-ray.
Is your question "Can this video/movie ever look good in a DVD5 sized file?" Depends on the source video.
Just a thought...What are you doing with the audio? If you just pass through a 5.1 or 7.1 audio stream you will be leaving almost no kilobytes for the video. -
Before the prices of BD-Rs came down and before I had a BD burner, I converted a number of discs from BD to DVD-5 or DVD-9. I used BDRebuilder and got amazingly good results. Truthfully, the DVD-9's were almost indistinguishable from the original BD unless you were looking very carefully for defects. The DVD-5's were not quite as good but were still way better than a purchased DVD.
SMK -
No I think what s/he is trying to ask is: "does losing 90% of great look better than losing 40% of good?"
Depends on the # of intermediate steps, the actual amount of loss, the quality of the algorithms, and the nature of the source material(s), esp. in its editing/motion/detail/complexity.
Freeware to compress dvd9 to dvd5?
By Topher5000 in forum DVD RippingReplies: 11Last Post: 27th Aug 2016, 09:49 -
How do I get a 3-hour video onto a DVD5?
By RowRowYourBoat in forum Video ConversionReplies: 16Last Post: 18th Oct 2015, 19:35 -
DVD9 to DVD5 with menus, best method?
By Jackpumpkinhead in forum DVD RippingReplies: 15Last Post: 22nd Jun 2014, 15:42 -
Splitting DVD9 into 2 DVD5's keeping menus, special features,be menu drive
By RBCC in forum EditingReplies: 2Last Post: 23rd Jun 2013, 18:00 -
DVD9 to DVD5 - How to obtain best quality rip
By jeffshead in forum DVD RippingReplies: 8Last Post: 10th May 2013, 08:58
