Do you have a model no so I can google it?
Results 1 to 9 of 9
Nearly all DTV converter boxes have both outgoing RF and composite video and stereo audio connections that the Mitsubishi HS-HD2000U could record from. I can't remember seeing any with S-Video out except for the CM-7000. (I still have one.)
So, when you say "Which HDTV receiver will work with Mitsubishi HS-HD2000U?", what do you mean by "work with"?Last edited by usually_quiet; 16th Jul 2017 at 16:52.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I mean OTA HDTV receiver with IEEE 1394 I/O so I can record and playback HD programmings.
Yeah so I think I'm looking for the rare Mitsubishi OTA HDTV receiver but I don't know the model no.
Maybe the Mitsubishi HD-5000 HDTV receiver controller is the item you are looking for.
Yes, that is it. Thank you.
Edit: There is also a much rarer Mitsubishi HD-6000.Last edited by digicube; 17th Jul 2017 at 08:54.
Do what you want, but I should mention that there is better technology available now for recording OTA HDTV in HD than a D-VHS recorder.
I'm into vintage technology. This is more of a toy.
Edit: I was able to record SVHS video onto a regular VHS tape by drilling a hole in the plastic shell. Does this mean I can do the same for DVHS? Has anyone tried it?Last edited by digicube; 17th Jul 2017 at 22:08.
How did I do? Mitsubishi VCR for $5?
By quxote in forum Capturing and VCRReplies: 4Last Post: 15th May 2017, 10:52 -
I cannot convert my old tv series files to work properly on a Samsung HDTV
By TV Addict in forum Video ConversionReplies: 8Last Post: 30th Mar 2017, 18:55 -
Mitsubishi WD 73738 problem
By fmitchelltx in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2016, 12:42 -
HDMI from Dell to HDTV but conflict with receiver
By moviegeek71 in forum DVB / IPTVReplies: 14Last Post: 2nd Aug 2016, 03:43 -
Anyone Help? SVHS to DVD Quality...Mitsubishi HS-HD2000U D-VHS , SVHS VCR
By lan2234 in forum RestorationReplies: 4Last Post: 21st May 2016, 04:41
