Hello,
A friend gave me a USB device with a mkv file on it, and I wanted to convert the movie into a m2ts file, in order to burn it on a BD. I prefer to watch movies on a Blu-Ray Disc rather than a USB key, especially when the film is long. I can stop, search backwards, play faster, and so on.
So I used tsmuxer to convert it, but my m2ts file is equal to 0 bites...
This is what I see on tsmuxer infos:
Network Optix tsMuxeR. Version 2.6.12. www.networkoptix.com
Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame rate: 24
H.264 muxing fps is not set. Get fps from stream. Value: 24
Decoding AC3 stream (track 2): Bitrate: 224Kbps Sample Rate: 48KHz Channels: 5.1
Decoding PGS stream (track 3): Resolution: 1920:1080 Frame rate: 24
Flushing write buffer
Creating AVCHD stream info and seek index
Creating AVCHD playlist
Mux successful complete
Muxing time: 0 sec
I don't understand why it does not work, do you?
Don't worry if you can't, I'll watch the movie using the USB device.
At least there is a name difference: AVCHD is limited to 8.3 names, IIRC... so .MTS instead of .m2ts at least.
Pixelation (broken pixels) occurs after muxing by tsMuxer. Why?
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Jul 2014, 23:37 -
Video out of sync when muxing with tsmuxer
By monks19 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2013, 14:01 -
tsmuxer - after muxing m2ts files out of sync by 2 frames
By Srivas in forum Video ConversionReplies: 1Last Post: 8th Aug 2013, 14:57 -
How to convert mpeg4 video (h 264) 25 fps to 23.98 fps?
By Novato07 in forum Video ConversionReplies: 1Last Post: 1st Jul 2013, 06:30 -
Video getting stuck after muxing with tsmuxer
By maxrockpro in forum Video ConversionReplies: 0Last Post: 15th Apr 2013, 05:03
