Hi all, i am having a bit of an annoying problem with windows 10 and mkv videos (more specifically mkv videos downloaded from youtube).
The issue is that windows try to display the thumb preview of newly downloaded mkv video but when it fails (always) it just hangs there trying to display it and the explorer gets unresponsive. The only solution is to log off and back on and NOT to open that specific folder again which have the mkv video.
This OS is running for almost 4 years (had win 7 then upgraded to 10, mirrored windows from hdd to ssd) and it have bunch of applications. I have been using Media Preview Configuration ever since Win 7 to make thumbnails for any video, i tried disabling mkv support but it doesn't fix the issue but rather make the thumbnail completely blank.
Any fix to this annoying problem? Oh and forgot to mention that mkv video file i have is a 4k video file (if it makes any difference).
Solved it, apparently its an issue with Media Preview Configuration utility, turning off mkv option did it although i no longer gets thumbnails for mkv format anymore.
Win. 7 (and on) with XP explorer easy interface please?
By bulgom in forum ComputerReplies: 11Last Post: 6th Nov 2015, 00:07 -
show Mkv's info in win folder
By vivabarca in forum ComputerReplies: 9Last Post: 4th Feb 2015, 10:44 -
By vivabarca in forum ComputerReplies: 1Last Post: 29th Aug 2013, 11:25 -
xvid4psp hangs reboots the computer and video quality on xp and win 7
By rated_x75 in forum Video ConversionReplies: 0Last Post: 10th Dec 2012, 07:47 -
How do I get flv thumbnail previews to show up in windows explorer?
By devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jul 2012, 09:59
