Hello. I'm trying to record this stream from vaughnlive however if i would use rtmpdumphelper the recording will stop one the window where the player is showing the stream is closed. Is there any way to run this from the command line?. I tried several methods but the token changes all the time and when i try to use rtmpdump will not open the connection. Can somebody help me with this?. If a screenshot is added so i can understand the steps would be much appreciated. Thanks in advance.
Results 1 to 16 of 16
Ponens,Code:
ffmpeg -i "https://hls-ord-2a.vaughnsoft.net:1443/ord/live/live_sherming5/playlist.m3u8" -c copy output.ts
I used the above code that you provided to download no problem. I'm curious how long would it take to download the complete video? Would it just keep downloading indefinitely? I aborted the download after a minute and the file that I got played fine.
Link to file:
https://files.videohelp.com/u/61125/jp.tsLast edited by jimdagys; 14th Jul 2017 at 07:36.
Ponens,
Can you tell/show me how you got the m3u8 link (https://hls-ord-2a.vaughnsoft.net:1443/ord/live/live_sherming5/playlist.m3u8)
I played the video and searched the network (Firefox adblock plus/Google chrome developer tools) and couldn't find any m3u8. -
Help! The code you provided is no longer working. Can you please update it ponens?. It would be much better if you show us how you did obtained that m3u8 link so i dont have to ask it everytime it changes.
Since your initial post, hls has been disabled for the stream. It was there when I initially checked it. Now it is gone (stream error: too many hls users).
I don't know if it will be enabled again.
Edit:
hls is enabled again, at least for the moment:
However, the http referer must be set to https://vaughnlive.tv/sherming5 or else 403 will be the result.Code:https://hls-ord-1a.vaughnsoft.net/den/live/live_sherming5/playlist.m3u8
Stream could change again. You'll need to check how the stream is being sent at the time you want to play/save it.Last edited by ponens; 17th Jul 2017 at 17:42.
Tubedigger ($15) seems to record (digitally, not screen capture) the stream. You can download the trial version of Tubedigger and it has a 2 minute record limitation. I have the paid version and it seems to record indefinitely the live stream. Here is a 4 minute sample that I recorded:
https://files.videohelp.com/u/61125/voot1.flv
If you use Tubedigger, you must use the following settings (see below screenshot red numbers).
1) click the circle #1 so that it says Monitor Browsers with a small ball in front
2) click circle #2 so that it says Rec Mode
2a) open Firefox or Chrome and start the live stream. Make sure the stream plays continuously (doesn't stop) in the browser.
3) make sure in circle #3 "Rec" is blinking
When you decide to stop recording the live stream, just close the browser (Firefox or Chrome) and Tubedigger will stop recording.
The file (flv) will be in the Tubedigger video folder (bottom of screenshot). The flv can instantly be converted to mp4 using Convert button (bottom of screenshot).
The recorded video should play perfectly, even though the live stream (played in browser) may be jerky. However, if the stream stops playing in the browser, then Tubedigger won't continue to record it.Last edited by jimdagys; 17th Jul 2017 at 10:23.
Something like this:
If it changes again, play the stream in browser and filter the network traffic to find the new url.Code:ffmpeg -headers "Referer: https://vaughnlive.tv/sherming5" -i "https://hls-ord-1a.vaughnsoft.net/den/live/live_sherming5/playlist.m3u8" -c copy output.ts
I just tried the above code that you gave (15 minutes earlier) and I get the following error message. What am I doing wrong?Code:
[https @ 02e0c860] No trailing CRLF found in HTTP header.
[tls @ 02e0c980] The TLS connection was non-properly terminated.
https://hls-ord-1a.vaughnsoft.net/den/live/live_sherming5/playlist.m3u8: Input/o
utput error
EDIT: I UPDATED TO LATEST ffmpeg (ver 3.3.2 July 11, 2017) and I was able to download the live stream on Windows 7 (but not Windows xp got dll error message). See bottom screenshot for Windows 7 command output - a little strange - but downloading OK.Last edited by jimdagys; 18th Jul 2017 at 11:36.
If you're using windows OS, try using newer build of ffmpeg.
http://ffmpeg.zeranoe.com/builds/win32/static/ffmpeg-20170711-0780ad9-win32-static.zip -
On Windows xp when I use the latest ffmpeg (3.3.2) I get this instant error message "entry point not found" (see below screenshot) when I paste in the above code. Using the previous version of ffmpeg I get CRLF error (see above screenshot). Using Windows 7 and latest version of ffmpeg I can download the stream no problem. Is there some kind of dll I can add to xp computer to fix the "entry point not found" error message?
Can you tell how to filter the network traffic and find the new url?. I'm using firefox and it is not working.
The video is hosted on http://vaughnlive.tv/sherming0 Please detail steps. Thanks in advance.
How to stream videos and record them directly from TV
By lucky113 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Sep 2016, 21:13 -
How to?: record/stream billiards
By billiardguy in forum Newbie / General discussionsReplies: 11Last Post: 9th Jan 2016, 19:36 -
Live Stream record
By Christian62 in forum Video Streaming DownloadingReplies: 2Last Post: 7th Feb 2015, 23:20 -
how to record a live stream, flowplayer, please help!
By moein in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2013, 21:20 -
How to record live stream from this site ?
By klp in forum Video Streaming DownloadingReplies: 3Last Post: 1st Apr 2013, 12:48
