I have used Python 3.6 (Anaconda to be exact) and written a script to build mingw-w64 cross toolchain.
It should work on Ubuntu 16.04 and Win10 WSL (Creators update)
If you have the spare machine power, you're welcome to test it, file bug report or refractor it.
Most of the logic follow zeranoe's script, except to avoid redundant building, multi-threaded download and remove multi-lib support.
The codes is now on GitHub:
https://github.com/MaverickTse/pyMingwBuild
Thank you.
Stopping development until someone save me from poverty or get me out of Hong Kong...
Twitter @MaverickTse -
Zeranoe just revamped his script and uploaded to GitHub!
https://github.com/Zeranoe/mingw-w64-build
so my unstable script is now useless
PC Build for 2016
By SameSelf in forum ComputerReplies: 30Last Post: 2nd May 2015, 10:17 -
Looking for build script to statically build ffmpeg, mencoder, mplayer,...
By Selur in forum MacReplies: 8Last Post: 11th Sep 2013, 15:13 -
New Build
By garystan in forum ComputerReplies: 5Last Post: 31st Jul 2013, 12:05 -
How can i Use VDub Script[.vcf] into Avisynth Script[.avs] ( Megui )
By Maskoff in forum EditingReplies: 1Last Post: 25th Jun 2013, 15:30 -
trouble adding a different script to a trimmed section in my script
By unclescoob in forum RestorationReplies: 20Last Post: 11th Aug 2012, 22:59
