I can remove silent parts of a clip's audio track in Audacity and shorten its duration. My issue is that I end up with a video track bigger then my audio track. I can Stretch it so it matches the duration of the shortened audio, but since the silence distribution is not uniform I will have many many places with audio and video out of sync.
I'm wondering if there's a tool out there that would allow me to truncate the silence and at the same time take care of the video sync?
Results 1 to 11 of 11
Best to use a Non Linear Editor, something like Magix (Sony) Movie Studio. See here for more suggestions
https://forum.videohelp.com/threads/382734-Software-that-allows-to-edit-both-video-and-audio -
I was looking for a way of having the video not just shrunk to the new audio length but also time remapped to recover sync. I don't want cuts to the video.
Sorry if I didn't word it right. -
You have to cut the video to keep it in sync . Video has a duration too (expressed as number of frames / frames displayed per second). If you cut the audio duration, but not the video, it will go out of sync
Or how did you expect to "time remap" it? Can you explain what you had in mind schematically ?
Lets say upper case is video , lower case letters are the corresponding video
Code:ABCDE abcde
sync problem
Code:ABCDE abde
Code:ABDE abde
Then you'll want a more advanced NLE like Premiere Pro or Vegas Pro.
I would recommend starting with the video, marking the start and end of where you want the time ramp to be at 100%, doing your speedup, and then cutting and pulling the audio back into sync. -
Time remap is possible with video vfr, but stupid WRT maintaining sync with audio.
Just imagine a countdown clip with frames visibly numbered and a flash at the first frame of each second corresponding to a frequency descending beep tone with offbeat marker clicks. And if instead of the tone, you find some loud airplane drone sound blaring between -6sec and -5sec.
Cutting audio out and time remapping the video will at best make something like the -7 to -6sec and -5 to -4sec sections be sped way up (with the timing of the beeps & clicks no longer matching the flashes nor the timecode). At least the remaining sections would be in sync.
Worse would be just time shrinking the vid to go from 10 sec to 9 sec: it may be constant framerate but everything before the cut would be visually early and everything after the cut would be visually late.
You must rethink your assumptions. Just use an NLE & do ganged cuts or inserts, or do small L cuts and remap surrounding segments or replace silence with something else.
Scott -
I'm struggling with the concept of editing out the silence in the audio. I don't understand why you'd want to do that if it's in sync with the video as it is. Maybe I'm missing something, but why not leave it?
If the silent sections aren't completely silent, but you want silence, why not reduce the volume until there's no sound rather than remove those sections and mess with the audio/video sync, or am I missing the point entirely? -
HOW TO REMOVE silence parts from a video?
By astamiga in forum EditingReplies: 6Last Post: 8th Jul 2015, 07:45 -
Sony Vegas cuts MP4 video's audio in half.
By Latias4Ever in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2014, 09:42 -
Avidemux audio problems. Audio cuts out after a while.
By nobodyhome in forum Video ConversionReplies: 7Last Post: 20th Oct 2014, 23:57 -
Easycap cuts my audio
By ianmcbubbles in forum Capturing and VCRReplies: 15Last Post: 21st May 2014, 12:38 -
how to remove silence from a video automatically??
By gabak in forum EditingReplies: 2Last Post: 27th Jan 2013, 09:57
