I have tons of videos here with Multiple Audio Languages at Subtitles , i was wondering if there are any programs that can remove the unwanted audio tracks and subs
Using MKVextact and Mkvmerge is a bit of a hassle since there are almost 500+ videos
or maybe there is an option to remove the audio from the source after extracting?
The only problem I see with automation, is tracks aren't always named appropriately and/or not in the same location (ie: English isn't always track 1 or default).
It often doesn't mean much space savings, so unless the wrong audio track is set to default, I leave it be. In any case, I use MKVToolNix.Google is your Friend -
for %%a in (*.mkv) do mkvmerge -o "output\%%~na.mkv" --audio-tracks eng --subtitle-tracks eng "%%a"
will only keep (in this example) the English audio and subtitle tracks.
But like Krispy Kritter said it requires all track languages to be set correctly or it will mess up. And it doesn't detect if there is no work to do (i.e. if there are no non-English tracks).
Newbie: Need help removing audio/subs from multiple videos mkvmerge
By haloboyvash in forum Newbie / General discussionsReplies: 9Last Post: 11th Jan 2015, 15:20 -
Removing Unwanted Audio Portions From a Video Clip
By D.V. Dee in forum AudioReplies: 3Last Post: 6th Apr 2014, 11:17 -
Removing audio distortion from video. Need your recommnedations.
By steve franklin in forum RestorationReplies: 5Last Post: 24th Jun 2013, 09:37 -
Removing Chunks of a Video Where Nothing Happen (Video and Sound)
By Mordan in forum Video ConversionReplies: 28Last Post: 16th Mar 2013, 09:48 -
Remove Hiss from Audio with removing or destroying the Audio
By Deter in forum AudioReplies: 8Last Post: 5th Mar 2013, 18:31
