Delete
1. Preferences->Multiplexer->Default values and disable "Automatically remove file title when the last file is removed". But this will only work when removing files from the Source files field. It doesn't work when closing/opening new tabs.
2. To disable statistic tracks go Preferences->Multiplexer->Default values and add Default additional command-line option: --disable-track-statistics-tags -
2.
Note:
- that will only deactivate/delete the statistic tags, not other global tags.
- you need to open a new tab (or restart MKVToolNix GUI) for the setting to take effect
- it will still show the "Global tags" "track" in the GUI but it will not be in the actual output file. Check output file with MediaInfo.
If you need more advanced automation I recommend learning how to write scripts (e.g. batch/cmd).Last edited by sneaker; 11th Jul 2017 at 15:21.
I think there's actually a bug - or two. Mkvtoolnix GUI doesn't detect the statistic tags written by ffmpeg as it would those written by itself. But the cli should work nonetheless. It's more of a cosmetic issue. ffmpeg seems to duplicate already existing ones or something like that.
It doesn't handle the ffmpeg tags the same way it handles its own tags. Not sure it actually qualifies as a bug. Either way I don't think there's currently any automatic way to get rid of them with MKVToolNix GUI.
MKVToolNix
By ThomasCSR in forum Video ConversionReplies: 6Last Post: 14th Jun 2017, 12:19 -
MKVToolNix 9.7.1 help
By zcool2016 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2017, 02:07 -
Need help using MKVtoolnix
By Larold in forum SubtitleReplies: 8Last Post: 6th Apr 2016, 08:00 -
MKVToolNix
By hardy in forum Newbie / General discussionsReplies: 23Last Post: 9th Nov 2015, 11:57 -
mkvtoolnix
By Harshad Patil in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2013, 08:17
