When playing video in both mpc/kodi it seems that it won't display accented letters like ō. (it's just an empty space in its place)
though they look fine in aegisub and notepad
how do i fix this?
What subtitle format are you using? What character encoding are you using? Today mostly UTF-8 should be used (test with and without BOM). Are they embed or separate file? Does the font you are trying to use include the "ō"?
"mpc" is what? Latest MPC-HC? With Internal Subtitle Renderer (ISR)? -
Ah i didn't even think of that, it must be it since when i changed the font to arial it appeared normally.
how do you know if a font supports it?
edit: I opened both the fonts with FontForge and the one that doesn't show it (called Profile-Regular) has the letters included in the font so i guess that's not it...
and yes i'm using utf-8, i'm not sure what you mean about BOM though.
this is an .ass subtitle file, i'm using MPC-HC with ISR.
with kodi the subtitles are rendered with xysubfilter.Last edited by Tylerr; 11th Jul 2017 at 10:23.
AnonymousGuest
I myself use the olde and goode charmap.exe.
Does FontForge say whether the font was authored properly?edit: I opened both the fonts with FontForge and the one that doesn't show it (called Profile-Regular) has the letters included in the font so i guess that's not it...
Including a character is not sufficient, the character must be assigned to the correct Unicode codepoint.
https://en.wikipedia.org/wiki/Byte_order_mark#UTF-8and yes i'm using utf-8, i'm not sure what you mean about BOM though.
BOM in UTF-8 is a misnomer, to begin with. This is a very-good reason to use UTF-16 instead. -
Latin Audio/Subtitles: not recognized. Why?
By antik85 in forum Authoring (DVD)Replies: 1Last Post: 16th Oct 2016, 19:02 -
Batch script for forcing subtitles on MKV files.
By hemstock in forum SubtitleReplies: 2Last Post: 9th Oct 2015, 16:40 -
A batch/Python script to Mux subtitles with video
By Scavvy in forum ProgrammingReplies: 4Last Post: 6th Jul 2015, 04:23 -
Avisynth script with subtitles - can i specify the size?
By Bully9 in forum SubtitleReplies: 11Last Post: 5th Jun 2013, 15:47 -
[HELP] Handbrake: multiple mkv to mp4 [SCRIPT] with subtitles
By remuxler in forum Video ConversionReplies: 2Last Post: 13th Feb 2013, 08:29
