My old 32 bit PC is dying and want to go 64 bits and stay with windows 7
I know 7th generation CPUs are only supported under W10 (no security updates)
So 6th generation CPUs may go for bargain prices (and motherboards)
i'm a hobbyist at editing ...and trying lots of stuff ...
and now most trialware and serious open source editing software are 64 bits.
So Blackmagic Design's Davinci Resolve seams really a must to try
and it's expected system specs are over the top ...but are they?
Now, What would you recommand fot PC built ?
NVidia GTX 1050ti? i'm kinda lost .. and really want to keep it under 2000$
ideally 1800$ i want spare change for a USB capture device.
Thanks to all
i still live in canada so maybe americans should read 1650$(us) instead of 2000$(can)
Results 1 to 11 of 11
I don't know about bargain prices on slightly older Intel chips as they don't really have a good response to Ryzen and Intel is still on Skylake, with Kaby Lake being an optimization and Coffee Lake coming out being yet another optimization. So if you don't want to go Ryzen then you still have to go with Skylake (or even Haswell). You could get pretty cheap FX AMD chips, like the FX-6300 and higher but I would not really recommend them for performance and efficiency reasons when you could spend a bit more and get a R5 1600 or even more for a R7 1700x.
Ryzen will work with Win7, its just you might have to set up Windows 7 with PS2 keyboard/mouse until everything is installed as Win7 does not support USB 3.0 during installation. Might have to also install some simple hacks that hide what CPU you really have from Windows (for automatic updates to work). I've also read about people just downloading the bundled update packs from Windows instead of using auto update, and it working. But I'll have to look into that more. Should say I'm still on Win7 and plan on staying for as long as I can too. -
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Well i got a response from my tech he suggested -
CPU i7-6700,
ASUS Z170-K
RAM. KINGSTON 2133, 16 Go
DISK 1 SSD SAMSUNG 250 Go
DISK 2 SEAGATE 6Gb/s, 1 To
VIDEO ASUS GTX1050 TI-4 Go
DVD LG 20X : 30 $
POWER SUPPLY COOLER MASTER 550 WATTS
TOWER COOLER MASTER 2 FANS
WINDOWS 7 HOME 64B
What do you think?
my old PC (i bought it used .) well the HDD died maybe i'll replace it and try to learn a little linux .. next winterLast edited by smartel; 11th Jul 2017 at 14:49. Reason: typo
You should consider getting a better video card. According to what I dug up with Google, DaVinci Resolve makes heavy use of the GPU and its memory for image processing, so it is important not to skimp there. See https://www.dcinema.me/davinci-resolve-system-requirements-a-reality-check/
[Edit]I almost forgot. The linked article also recommended using a large capacity SSD or HDDs in a RAID configuration for storage.Last edited by usually_quiet; 11th Jul 2017 at 15:40.
and what would be a quality/price card for this ..i can get the ASUS for around 230$(can) the 1060 blows the 400$ mark
i will do SD, no HD or 4K .. and i can change it later ..
isn't that configuration guide for 4K/realtime editing? -
You never mentioned that you were only planning to work with SD video before now.
The linked configuration guide for DaVinci Resolve includes requirements for both HD and UHD material, but nothing for SD.
I'm guessing that the author did not expect people working exclusively with standard definition video would be interested in using DaVinci Resolve.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
well davinci resolve does a lot of great things ...multicamera and audio too ..
and if my future pc can drive this ...well would also drive any other software..
and doing SD isn't a sin ..Last edited by smartel; 11th Jul 2017 at 16:29.
Note, Resolve does not support most, if any, AVI formats (e.g. LAGS, UTVideo, DV-AVI, etc.) and AFAIK, only supports uncompressed UYVY, the format BMD's capture cards use. This makes editing SD content a challenge, necessitating a transcode of all your capped footage prior to ingest. Of course, some people will jump through all kinds of hoops because they love the Resolve koolaid. If you told me that you shoot 4K in a flat/sLog/cine or some other profile that requires custom LUTs/grading prior to any editing, ok. But, this is SD footage, and there is nothing that you will be able to do in Resolve that you can't do in any other capable NLE. In fact, Resolve will mangle your footage some because it does not operate in YUV space. I am repeatedly nonplussed why people are willing to spend thousands of dollars on new hardware to get Resolve up and running but not $50 to $100 on a capable NLE that will run great on their current system.
Which if any version of DaVinci Resolve works with XP 32 bit?
By brassplyer in forum EditingReplies: 3Last Post: 9th Jan 2017, 15:19 -
how do i resolve the message 'access is denied' on my laptop c: drive?
By vhelp in forum ComputerReplies: 7Last Post: 31st Mar 2016, 22:47 -
Davinci Resolve 12 NLE
By SameSelf in forum EditingReplies: 11Last Post: 7th Feb 2016, 09:16 -
How to resolve some errors with avs script?
By robusco in forum Video ConversionReplies: 12Last Post: 4th Dec 2015, 12:37 -
Help to resolve FFMPEG Unrecognized option 'preset' “ error
By chrisj in forum Newbie / General discussionsReplies: 13Last Post: 24th May 2014, 18:15
