Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jul 2017
    Russia
    Hi all!
    Very long time I try to fix problem with mpv on my computer.
    I use Debian. Problem was with Jessie and now with Stretch.
    When I try to open in mpv file with 5.1 DTS sound or 7.1 mpv always tell me [ao/alsa] Asked for 6 channels, got 2 - fallback to stereo.
    For example:
    mpv --audio-device=alsa/iec958:CARD=Juli,DEV=0 --alsa-ignore-chmap 00001.m2ts
    Playing: 00001.m2ts
    (+) Video --vid=1 (h264 1920x1080 23.976fps)
    (+) Audio --aid=1 (dts 6ch 48000Hz)
    Audio --aid=2 (ac3 6ch 48000Hz)
    Audio --aid=3 (dts 6ch 48000Hz)
    Audio --aid=4 (ac3 6ch 48000Hz)
    Audio --aid=5 (dts 6ch 48000Hz)
    Audio --aid=6 (ac3 6ch 48000Hz)
    Subs --sid=1 (hdmv_pgs_subtitle)
    Subs --sid=2 (hdmv_pgs_subtitle)
    Subs --sid=3 (hdmv_pgs_subtitle)
    Subs --sid=4 (hdmv_pgs_subtitle)
    Subs --sid=5 (hdmv_pgs_subtitle)
    Subs --sid=6 (hdmv_pgs_subtitle)
    Subs --sid=7 (hdmv_pgs_subtitle)
    Subs --sid=8 (hdmv_pgs_subtitle)
    Subs --sid=9 (hdmv_pgs_subtitle)
    Subs --sid=10 (hdmv_pgs_subtitle)
    Subs --sid=11 (hdmv_pgs_subtitle)
    Subs --sid=12 (hdmv_pgs_subtitle)
    Subs --sid=13 (hdmv_pgs_subtitle)
    Subs --sid=14 (hdmv_pgs_subtitle)
    AO: [alsa] 48000Hz stereo 2ch s16
    VO: [opengl] 1920x1080 yuv420p
    AV: 00:00:01 / 01:56:10 (0%) A-V: -0.000
    VLC work good and I always have DTS passthrough
    I tryed to use many variants.
    If I try to show to mpv how many speakers I have he show me another message
    mpv --audio-device=alsa/iec958:CARD=Juli,DEV=0 --audio-channels=fl-fr-bl-br-fc-lfe --audio-spdif=dts-hd,ac3 00001.m2ts
    Playing: 00001.m2ts
    [ao/alsa] Asked for 8 channels, got 2 - fallback to stereo.
    Passthrough format unsupported.
    Maybe anybody can show me the right way for fixing this problem?
    Thanks to all!
    Mar 2011
    Nova Scotia, Canada
    I use Linux but it's Mint, not Debian, and I don't use mpv. I suspect you may have better luck on the debian forums.
    However, I did find this bugzilla, and it doesn't look resolved ...
    https://github.com/mpv-player/mpv/issues/1313
