is it true if you buy a new kaby lake processor you cant use windows 7 regards jovie
Microsoft doesn't support the use of Windows 7 with a Kaby Lake CPU. You may still be able to use a Kaby Lake CPU, but there is no guarantee that it will function correctly, and the system won't receive updates other than security updates. (There is a unsanctioned patch to enable updates: https://www.extremetech.com/computing/248069-unofficial-patch-unblocks-windows-7-8-1-u...aby-lake-ryzen)
However, some publications have said that such a system could be somewhat unstable, and users may need to buy a discrete video card because Kaby Lake's iGPU won't work correctly, due to a lack of drivers. (The available Windows 7 iGPU drivers are beta software.)
If someone needs to use Windows 7 for specific software, a VM may be a better way to go.Last edited by usually_quiet; 10th Jul 2017 at 12:12.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
thank you for your reply shall have a long think before i decide which system to build next regards jovie
Skylake X and Kaby Lake X CPUs are available for purchase.
By usually_quiet in forum ComputerReplies: 2Last Post: 28th Jun 2017, 12:05 -
Kaby Lake Quick Sync; thoughts, opinions?
By ziggy1971 in forum Video ConversionReplies: 1Last Post: 17th Jan 2017, 17:19 -
Kaby Lake x264 Benchmarks (Desktop)
By ezcapper in forum Video ConversionReplies: 4Last Post: 8th Jan 2017, 13:56 -
Does Kaby Lake Beebox work with Magewell USB Capture?
By ezcapper in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2016, 15:58 -
Kaby Lake i7 7700k "reviewed"
By sophisticles in forum ComputerReplies: 1Last Post: 1st Dec 2016, 15:27
