Not automatically but you can use this method manually to change the pitch of an existing sound. Each time he misses, you would do the following. (I saw this answer on another forum for an older version of Vegas. I don't know if it will work with your version)
enable View > Active Take Information (Ctrl/Shift I)
For the record:
- or + buttons on their own change pitch a semitone at a time
Ctrl - or Ctrl + changes pitch One Hundredth of a semitone at a time
Shift - or Shift + changes pitch 12 semitones, or one octave.
Make sure you select the audio event first.Extraordinary claims require extraordinary evidence -Carl Sagan
Can you automate VideoRedo
By cgott42 in forum EditingReplies: 5Last Post: 17th Dec 2024, 20:31 -
[Sony Vegas] how to automate the "color gradient" plugin's Control Points?
By rocco123 in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2017, 23:34 -
Vegas: Out of sync sounds when using Pitch Shift effect
By rocco123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2016, 07:30 -
Any way to automate a number off conversions?
By StumpedTechy in forum Newbie / General discussionsReplies: 1Last Post: 14th Jun 2015, 14:10 -
how do i automate a website
By RBCC in forum Video Streaming DownloadingReplies: 8Last Post: 8th Nov 2014, 17:03
