I would also vote for 720x480 because it is a DVD standard. Despite the funny "what is a DVD?" comment, DVDs are still my recommendation for the media onto which you should archive VHS/8mm/Beta video.
Why?
Longevity.
Yes, you will have to do an addition encode to MPEG-2, and yes, this will introduce some additional blocking artifacts. However, if you use a good MPEG-2 encoder and use a high bitrate e.g., 8,000,000 bits per second VBR), those additional artifacts will still be swamped by the lousy quality of consumer SD tape-based analog video.
As for longevity, I have read dozens of studies, using accelerated aging, about how long good-quality (and that is IMPORTANT) DVDs will last, but 100+ years is a common estimate, if the discs are stored in cool, dark storage areas.
By contrast, hard drives will certainly not continue to spin for 100 years; and solid state memory is VERY vulnerable to ion migration (where the charged particle migrates up through the oxide layer) and is unlikely to last more than a decade or two. Tape is quite good: I've transferred audio tapes from the late 1940s, right after magnetic tape replaced wire recorders, and they have held up very well. However, the mechanisms for playing home tapes (like VHS or 8mm tape decks) are already starting to break down, and many people are finding that they can no longer play their tapes on the one VHS deck remaining in their house. The helical scan mechanism is pretty fragile and prone to alignment issues, and it is getting very hard to find people who can repair or re-align the decks.
Some people argue that there will be no equipment to play round shiny objects (CD, DVD, and Blu-Ray) in fifty years, but I actually think they will still be quite common. The CD was introduced in 1984 which is 1/3 of a century ago, and I have over a dozen devices withing fifty feet of where I'm typing this that can still play them. The industry has done a great job of backward compatibility (5 1/4 inch form factor, for one), and most modern devices can still play DVDs and CDs.
I can still easily find equipment to play vinyl records, and they are been around since 1950, so some formats do persist for a long, long time.
Results 31 to 34 of 34
Optical drives will be off the market within 30 years. That's my prediction. Everything is headed to the cloud. We are among the last generations of casual users who can be bothered with local storage.
Oh, thanks for the help. So a line-TBC from a DVD/VHS player is superior to my CCD trv85's built in TBC? I get that I need one for VHS tapes, but how about video8 tapes?
How do you check if your DVD/VHS has a line or frame TBC of if it has one at all? I wouldnt mind buying a frame TBC if itd make my home8 and VHS tapes look even better than a line TBC. -
VHS Digitizing - Newbie Questions
By chilly_willy1 in forum Capturing and VCRReplies: 5Last Post: 19th Nov 2016, 11:44 -
New to Potplayer; a couple of questions.
By Eric321 in forum Software PlayingReplies: 1Last Post: 15th Mar 2016, 03:14 -
Trying to learn ripbot264....... a couple of questions
By True Colors in forum Newbie / General discussionsReplies: 10Last Post: 31st Mar 2014, 01:24 -
Questions about 'remastering' films
By alex101 in forum RestorationReplies: 35Last Post: 15th Jul 2013, 02:50 -
Digitizing Hi8 for storage/editing and dvd
By Ranubis in forum Newbie / General discussionsReplies: 35Last Post: 27th Jun 2013, 07:04
