Trying to convert my rips from JL Blurays to MKV. Saw this odd color swap when I converted. Made the desks darker for some reason. Any advice? I am using the Fast 1080p Setting.
screenshotcomparison.com/comparison/214704
May need PC to see compare.
It's not a big difference, some loss in grain and noise in the screenshot. I wouldn't call it "color change" . Use better settings or higher bitrate if you wanted to preserve the noise better
I resized one compare, you can flip back/forth
Are you seeing this in your video playback ? Maybe it's a playback configuration issue ? Or screenshot issue ?
Subtitles Change Color
By lomaidala in forum SubtitleReplies: 5Last Post: 18th Jan 2016, 17:09 -
Show a color picture as part of subtitles
By cdlvcdlv in forum SubtitleReplies: 0Last Post: 19th Jun 2015, 06:21 -
Color change after encode
By Tylerr in forum Video ConversionReplies: 8Last Post: 7th Jan 2015, 08:31 -
Hanbrake Anomorphic Settings
By comp1mp in forum Video ConversionReplies: 22Last Post: 31st Mar 2014, 20:33 -
Did the hyperlink color change or is it just me?
By yoda313 in forum FeedbackReplies: 6Last Post: 25th Apr 2013, 02:46
