I have a batch of files I encoded to HEVC with vidcoder. For the ones that already had subtitles muxed, it kept them. For the ones where the subtitles were an identically named SRT file, it didn't include them in the output.
Is there a way to mux them with vidcoder, setting video and audio to passthrough, or do I need another program?
I've searched for how to do it for MP4 but Google insists I mean MKV, Matroska, AVI or formats other than MP4.
	It's easy if they were MKV SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	In megui go to: Tools > Muxer > MP4 muxer
 In staxrip go to: Tool > Scripts > Re-mux
 In powershell it looks like in a batch file except you need to precede it with the call operator other powershell would interpret the mp4box path as string instead of a command.
 & "D:\Apps\MP4Box\MP4Box.exe" -add "D:\Temp\aaa.mp4#video" -add "D:\Temp\aaa.mp4#audio:lang=eng:name=" -add "D:\Temp\aaa.srt:lang=eng:name=" -new "D:\Temp\aaa_new.mp4"
	MeGUI works but the Queue button doesn't actually do that. It instantly begins muxing instead of putting it into a Queue of jobs to be started later, even with the and close box unchecked. Also have to manually select the video file for both audio and video and select the subtitle file.
 Works but tedious. :P
 I've been trying the muxing with StaxRip without success. I see it has functions for handling folders and subfolders - but what do I need to do to have it take a folder full of MP4 files and identically named SRT files and just mux the matched name pairs? What I get are walls of text reporting various errors.
 A tool that does that and only that would be very nice. Run it, drag and drop a fold onto it and it muxes any set(s) of files with the same names but different extensions, keeping the extension for the output from whichever file in the set has the video stream.
	Please post the full log file to pastebin.but what do I need to do to have it take a folder full of MP4 files and identically named SRT files and just mux the matched name pairs?
 https://github.com/stax76/staxrip#support
  How to easily burn in/hardcode srt subtitles to mp4/mkv with VidCoderBy Baldrick in forum User guidesReplies: 65Last Post: 25th Jun 2024, 03:11
  How do I convert MKV to MP4 in batch with burned-in subs? (Vidcoder)By fighuass in forum Video ConversionReplies: 12Last Post: 29th Aug 2021, 13:02
  How to extract only forced subtitles with a batch muxing using mkvmerge?By davboc in forum EditingReplies: 1Last Post: 1st Jul 2016, 14:28
  Batch muxing video files with subtitlesBy calexicoca in forum SubtitleReplies: 4Last Post: 16th May 2015, 10:31
  Batch muxing and demuxing mp4 filesBy Island_Dweller in forum Video ConversionReplies: 3Last Post: 17th Aug 2014, 11:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
