As others have mentioned on here, the quality of capture including the ability to do 640 by 480 is great off of the DC10 plus.
My goal - the best quality capture from VHS to DVD.
The problem - the eventual MPEG2 encoding is painfully slow on every encoder I have tried so far - I think due to the MJPEG compression in the AVI file.
Has any one else find a way around this ? Perhaps capture at a lower resolution or use some MPEG2 encoder I haven't tried yet ?
Hardware - 1200 MHZ AMD Athlon, 256 MB Mem, 7200 RPM ATA100 drives
Software - Win98 - Pinnacle Studio 7
First, can you capture at 720 x 480 (DVD resolution) ?
Second, conversion from AVI or MJPEG to MPEG-2 is always slow using software. Some software may run faster, some slower.
For example, using TMPGenc, my system (identical to yours) takes 4 hours to convert a one hour AVI (at 720x480 res) to DVD format.
Hope this give you a baseline.ktnwin - PATIENCE -
Here's how I do it:
1. Capture Using AVI_IO / DC10plus at 640x480, 2 fields, 6000kbps
2. Frameserve using AVISynth
- Use "separate fields"
- Bicubic resize to 480x480
- Use "Weave" to re-interlace fields
3. Encode to MPEG-2 with CCE 2.50 (patched to fix CRC error)
- Uncheck "force upper field"
4. Build BIN/CUE file with VCDEasy
5. Burn with CDRWIN
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Best quality (Not speed) Converter for miniDV to Mpeg2
By AussieHusky in forum Video ConversionReplies: 5Last Post: 2nd Nov 2007, 00:54 -
DC10 Plus Capture
By jackylhome in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 17:12 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
