I recently purchased a ATI TV-Wonder and have had some luck recording to MPEG-1 (this seems to work just fine) quality is good and i've had no real problems to speak of.
however, the files i record useualy end up being 1.4 to 2.2GB in size and i want to encode to DivX to trim them down.
I'm using VirtualDub 1.4d to convert my video files
using
Video Compression:
DivX Mpeg-4 Codec (4.0 a50)
using the default settings
Audio Compression:
DivXAudio
using 64kbps, 44 kHz, stereo for DivX
i've tried using the 128 kbps, 44kHz, stereo but it just craps out and dosn't convert... i'm using the 64kbps because it works...
what the problem is...
once i encode to DivX the sound seems to have a 3 to 4 second delay... and isn't at all useable...
Am i doing something wrong?
Results 1 to 1 of 1
Lacie 1TB LaCinema Classic HDMI EK - mpeg or divx with 5.1 sound
By Dirk in forum Newbie / General discussionsReplies: 6Last Post: 3rd Feb 2010, 02:17 -
weird sound after noise removal in audacity
By happydog500 in forum AudioReplies: 25Last Post: 3rd Oct 2008, 09:24 -
Slow FPS and weird sound problems
By desantnik in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 13th Dec 2007, 17:33 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 13:56 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 04:16
Audio
