Chrome for example doesn't have any problems but I like Internet explorer, so can you thing what is happening? Internet explorer doesn't seem to have problems with other sites and even I reset it still the same problem.
Thank you in advance!
Results 1 to 12 of 12
I also use IE11 (as well as Chrome) and I do experience random crashes (brings the whole system down) with IE11 (Win7-64)
Would not begin to suggest why this happens but it does. -
This tip (even though it is old) seems worth a try:
http://windowsreport.com/fix-internet-explorer-11-crashes-windows-8/
place a check mark next to “Use software rendering instead of GPU rendering” which you can find in the “Acceleration graphics” topic. Click(left click) on the “OK” button situated in the lower side of the window. Reboot the Windows 8 PC...crash on certain pages after june 2017 update (microsoft.com)
...Known Issues in KB4032782 and KB4022168
After you install this update, Internet Explorer 11 may crash when you visit some websites. The problem may occur if the website is complex and uses certain web API's.
Microsoft is researching this problem and will post more information in this article when the information becomes available. -
Marsia MarinerGuest
IE 11 on W10 crashes regularly for me on quite a few sites.
Never had the problem with the earlier versions.
I assume it's just a poorly written program. -
I always avoid IE. It is just a painful browser and better to avoid.
Have a look at your Reliability History, control panel>security and maintenance>maintenance,if there are red flags and if the only option given is"check for a solution"put your cursor on it BUT RIGHT CLICK ONLY.This will give you another option :View tech details",LEFT click on it and you will be given a page of data,the line identified as Bucket id shows the problem and allows you to copy and paste for a search.Never bother with "check for a solution",if there was one there would not be a problem.
This is the main reason why keep out from using IE. Not only about this site, but it is also crashed when i am editing my file on excel online, it is worst because i lost all of my editing.
ppl still use IE? Must be the same ppl who get WannaCry. This is 2017, not the 90s. There are other options besides Microsoft.
Home Theater -- No forum for them on VideoHelp I guess.
By marjamar in forum Newbie / General discussionsReplies: 6Last Post: 31st Jan 2015, 16:17 -
very slow download from forum.videohelp.com
By vhelp in forum FeedbackReplies: 26Last Post: 2nd Feb 2014, 22:37 -
Why does internet explorer still come with Windows?
By yoda313 in forum ComputerReplies: 17Last Post: 16th Sep 2013, 04:01 -
MKV keeps crashing Windows explorer when cursor is held over it
By Onceler2 in forum Newbie / General discussionsReplies: 21Last Post: 21st May 2013, 16:43
