The DVDs I'm trying to rip are Warner bros. (several and various Looney Tunes titles from the past 6-7 years). They were purchased used but LOOK to be in good condition.
I do see the copy protection logo on the back of all these DVDs:
Encountering the following problems when TRYING to rip to PC:
(a) horrible scandisc results (using Nero DiscSpeed). I.e., massive and continuous "bad" (red) sectors in various parts of a scanned DVD. But I have used MUCH WORSE scratched discs that are all in the green.
(b) DVDFab encountering errors, which I can't "Ignore" or "Ignore All". It just gets stuck at a certain % level !! Also, when DVD Fab gets stuck, the DVD drive gets noisy (trying to focus, slew, access, etc.)
(c) Can't copy many files directly in Windows (i.e., copy and paste from DVD's VIDEO_TS to my hard-drive) -- some files will just get stuck in the middle of paste (no warning, no errors messages, no nothing!!)
I have ripped 100s of DVDs, many with some copy protection, but these Warner titles are confusing.
Given the problems noted in (a), (b), and (c), am i running into copy protection "blocks"?
P.S. I am trying DVD Decrypter as last resort (it's running now) -- and it seems to be doing better...but boy is it slow. Will report back later!
P.S. 2: While I haven't played all the DVDs (directly), they seem to play and navigate okay. BTW: I only have computer-based (drive) players.
Okay, here is what the ScanDisc looked like:
The DVD Decrypter rip crapped out
But the DVD plays fine in all software players and on various PC/laptops I use.
Just can't seem to rip! -
That worked! And it was a totally smooth rip, too. Before, DVDFab, when ripping, would get very memory or CPU intensive. But disabling pathplayer did the trick.
About cleaning ... should've noted before that not only were they thoroughly cleaned, but (and esp. after seeing the ScanDisc) resurfaced using SkipDoctor. No difference (ScanDisc looked exactly the same).
BTW ... about that ScanDisc...WTF!!!!!!!!! does copy-protection encryption create that type of scanning?
DVDFab can Handle Cinavia Protection?
By devilcoelhodog in forum DVD RippingReplies: 30Last Post: 7th Mar 2016, 07:34 -
Having some issues with Makemkv and DVDFab i need advice on please
By Bigdog97609760 in forum Blu-ray RippingReplies: 4Last Post: 29th Nov 2015, 18:44 -
Lots of BD+ protection issues lately using DVDFab Blu-Ray ripper
By WebMaximus in forum Blu-ray RippingReplies: 7Last Post: 7th Mar 2015, 14:27 -
how does the copy protection work on a copy of the copy protected tape?
By opie390 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2014, 18:18 -
Copy but maintan Copy Protection intact?
By jcarlberg in forum DVD RippingReplies: 10Last Post: 18th Oct 2012, 16:41
