  1. I love PotPlayer features but I realized that it reproduces video files more darker and with red hues than others players like VLC or even Windows Movies. I tried to solve with by touching in the control panel, but I didnt get the same quality. I think its due to the codec or video filters configuration. So I want to setup the PotPlayer to use the same codecs and filters. But I dont know how to do it Please, help.
  2. It's most likely because your video card has some sort video enhancing features enabled that effect PotPlayer and not VLC (for VLC I think it depends on the renderer it's using).
    If you referred to Potplayer's control panel, reset it and then go to your video card's control panel and make sure anything that could effect the video quality is disabled. That's probably the first place to look.
