i hav cd-writer n i wanted to copy my vcd to the cd-r but when i selected the option cd copy and finish burning, it cant work. when i played it on my comp, it showed the cd has unsupported file... wat actually happen? how to correctly burn the vcd to cd-rw? pls help me... thanxz a million!!! :(
Well First of all are you copying A vcd to CD-r or the MPEG files? answer me that first then perhaps I can help.
-CDBURNER -
i wanted to copy A VCD to cd-rw but cant... i just use cd copy command but after finish burning the vcd player cant read the cd-rw. how come?
izzit not supposed to do tis way? pls help... really thanxz. -
Is this a stand-alone VCD player??
Stand-alone VCD players are based around a standard CD-ROM drive. Most CD-ROM drives cannot read CD-RW media.
Regards.Michael Tam
w: Morsels of Evidence -
erm... i only hav one cd-rw drive n i using tis drive to copy the vcd to cd-rw. after tt i try to watch but the it showed no supported files found. how? pls help... thanxz.
Which burning program are you using?
Perhaps you could try another one ... e.g., CloneCD or CDRWin.
Regards.Michael Tam
can someone help me in encoding avi to vcd format (mpeg)
1) i used v-dub to extract the audio as a wav then saved it
2)went in tmpenc and coverted the avi to mpeg input the wav file as audio
3) encodin went fine using tempenc --NO errors
4) then i tried to play the mpeg file in media player but only the audio worked no video (black SCREEN)
any suggestions -
eerrm....im using sony cd maker 2000. it comes wif the cd-rw
drive whe n i bought it. how to get other program and btw can
it be used wif any cd-rw drive?
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 07:42 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 05:50 -
how to copy the contents from a scratched vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 36Last Post: 28th Dec 2007, 03:03 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 01:34 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20
