Hi,
considering either Sony AX53 or Canon G40 for airshow (prop aircraft ) filming in flight from the ground on shutter priority and exposure compensation. Now a dslr would require +3 comp, the G40 has -3 to +3 exp comp available, Sony v odd just -1 0 +1, no good for anything be it snow or sand or sky unless in the world of camcorders (or just theirs) thats enough for the brightness of the sky to ensure aircraft correctly exposed.
So why the apparent hardly worth having exp comp range or is it equivalent to dslr -3 0 +3 ?
and why do other camcorders have -3 0 +3 ?
DBenz
Exposure is one of the front ring options on the AX53. It has a range of many stops. Never measured it or looked it up, but I've always been able to nail the exposure.
Hi, whilst exposure is a combination of shutter and aperture, and I will be filming on 1/50 sec, has it a suitable aperture for sunlight when on this shutter speed ?
The key thing I also need to know is that Exposure Compensation, can you set yours to 1/50 and let me know what aperture it is choosing for a sunlit scene, grass etc, then aim it at the sky with white clouds and chimney or something, and dial in the exposure compensation that it offers, a max of +1 from what I see, and tell me if the chimney is the same appearance as when filmed with mostly ground in the shot.
Better still take two photos, show those.
DBenz
Issue with the exposure changing as I move
By tomlis20 in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2017, 20:27 -
Recording in XAVC S HD on Sony FDR-AX53
By Gil T Remnant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Oct 2016, 14:41 -
Please suggest a good microphone solution for Sony AX53 camcorder
By Srivas in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Oct 2016, 11:05 -
Freezing auto-exposure
By timsky in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th Jul 2016, 18:48 -
Ho to Download videos from Sky Go http://go.sky.com
By mrwolf in forum Video Streaming DownloadingReplies: 1Last Post: 1st Feb 2015, 04:53
