I have downloaded few movies which are large at size (full hd) 20+GB, but I was forced to recode them to lower bitrate to be able to stream properly over my networkI was able to figure out my TV can play a video fluently @ 25 Mbps tops only and TBH that doesn't sound like a very low bitrate for 4k video
, unfortunately however when i encoded part of the video with xmedia recode on up to 20 Mbps (2-pass) the result was, well, bad
I am sure i read while back here on the forums that even 2 pass encoding cant guarantee the quality at that rate, compare a native video at 20Mbps say with another recoded there WILL be difference, my question is how to get around this knowing that the maximum bitrate my tv can play remotely is 25~ Mbps but i also want it to be in a good quality, i know that because i downloaded few movies on that quality and it looked superb, so i want to replicate such results, any guidance would be greatly appreciated...
Thanks,
2pass usually targets an average bitrate. But an average does not guarantee the absence of spikes exceeding TV decoder or wifi limits. Instead you would limit via vbv maxrate. Then you can even use single pass crf encoding safely (assuming x264 or x265)
How to do that in xmedia recode or any other encoding tool you really recommend for professional use ?...
In Xmedia set "Rate control mode" to "Quality". Then in "Rate control" you can set "VBV Maximum Bitrate" and "VBV Buffer Size". "VBV Maximum Bitrate" is your wifi speed/TV decoder performance (whatever is lower).
Note: I don't know if that's the cause of your issues. Just going by what you have told me which isn't much. I don't know about formats, TV model, etc.
Xmedia Recode - Ripping & Encoding about 50% only
By Paparazzi in forum Video ConversionReplies: 3Last Post: 3rd Nov 2016, 02:18 -
XMedia Recode frame rate encoding
By 55trucker in forum Video ConversionReplies: 10Last Post: 25th Oct 2014, 22:08 -
XMedia Recode
By Arthur_Ballsack in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2014, 05:30 -
xmedia recode
By MaxOne72 in forum Video ConversionReplies: 3Last Post: 7th Dec 2012, 13:09 -
Xmedia Recode help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 12:36
