Can someone pls tell me what this means and if I should worry?
Code:[libx264 @ 00000000035f1fe0] direct=auto not used on the first pass
It means you didn't use direct auto on the first pass but activated it in a following pass. You shouldn't do that but it's not the end of the world.
Thanks. That is very strange though because I did not include it in the second pass either unless there is some other option that implicitly invokes it. I use the x264 BD authoring guide, and there is no direct=auto option in any of those examples. Not sure how this crept into my scripts.
Presets slow to placebo imply direct auto but irregardless of the pass. So you must have set different settings explicitly.
I did not know that. Thanks. Since my preset is veryslow, the question is now, what option is turning it off? I guess I will just add direct=auto to my script.
You must have done it.
Maybe you ran the first pass with a different preset and the stat file was still there?
Either way it's your fault. Just delete the stats files, do a proper 1st/2nd pass and the problem will be gone. If not post the complete command-lines and logs.
exploit warning
By aedipuss in forum FeedbackReplies: 3Last Post: 29th Apr 2013, 14:49 -
ffmpeg how to "lossless" convert video codec to libx264 ? CRF & qp value
By feelart in forum Video ConversionReplies: 3Last Post: 9th Jan 2013, 20:46 -
mpeg2video vs. libx264: Why the huge difference in filesize?
By yetanotherlogin in forum Newbie / General discussionsReplies: 4Last Post: 18th Dec 2012, 07:55 -
libx264 & ffmpeg (0.11.x) understanding quality options -q:v and -b:v
By feelart in forum Video ConversionReplies: 3Last Post: 19th Sep 2012, 09:39 -
Update libx264 in ffmpeg
By NGage^ in forum Newbie / General discussionsReplies: 2Last Post: 11th Sep 2012, 10:25
