0
down vote
favorite
I am trying to create a so called origin server for storing the hls chunks and the manifest file on a remote server. The sending machine running ffmpeg is with IP: 192.168.178.50 and the web server which has to store both the HLS chunks and the manifest file is with IP: 192.168.178.100. My ffmpeg transcoding command line is:
But no matter what method I am using I got in the access log of my apache web server the following errors:Code:$ ffmpeg -i 01_llama_drama_1080p.mp4 -profile:v high -level 5.2 -s 1920x1080 -strict -2 -start_number 0 -hls_time 6 -hls_list_size 0 -f hls -method PUSH http://192.168.178.100/hls/test.m3u8 ffmpeg version 2.8.11-0ubuntu0.16.04.1 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.4) 20160609 configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '01_llama_drama_1080p.mp4': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: isommp42 creation_time : 2013-02-08 18:56:45 Duration: 00:01:30.00, start: 0.000000, bitrate: 3120 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080, 2925 kb/s, 24 fps, 24 tbr, 48 tbn, 48 tbc (default) Metadata: creation_time : 1970-01-01 00:00:00 handler_name : VideoHandler Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: creation_time : 2013-02-08 18:56:46 handler_name : IsoMedia File Produced by Google, 5-11-2011 [libx264 @ 0x249b880] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2 [libx264 @ 0x249b880] profile High, level 5.2 Output #0, hls, to 'http://185.71.86.48/hls/test.m3u8': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: isommp42 encoder : Lavf56.40.101 Stream #0:0(und): Video: h264 (libx264), yuv420p, 1920x1080, q=-1--1, 24 fps, 90k tbn, 24 tbc (default) Metadata: creation_time : 1970-01-01 00:00:00 handler_name : VideoHandler encoder : Lavc56.60.100 libx264 Stream #0:1(und): Audio: aac, 44100 Hz, stereo, fltp, 128 kb/s (default) Metadata: creation_time : 2013-02-08 18:56:46 handler_name : IsoMedia File Produced by Google, 5-11-2011 encoder : Lavc56.60.100 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (aac (native) -> aac (native)) Press [q] to stop, [?] for help [hls @ 0x24997e0] Cannot use rename on non file protocol, this may lead to races and temporarly partial files
These are the supported methods on my web server:Code:$ tail -f /var/log/apache2/access.log 192.168.178.50 - - [27/Jun/2017:10:40:45 +0000] "POST /hls/test.m3u8 HTTP/1.1" 404 469 "-" "Lavf/56.40.101" 192.168.178.50 - - [27/Jun/2017:10:40:45 +0000] "POST /hls/test12.ts HTTP/1.1" 404 469 "-" "Lavf/56.40.101" 192.168.178.50 - - [27/Jun/2017:10:40:46 +0000] "POST /hls/test.m3u8 HTTP/1.1" 404 469 "-" "Lavf/56.40.101" 192.168.178.50 - - [27/Jun/2017:10:40:46 +0000] "POST /hls/test13.ts HTTP/1.1" 404 469 "-" "Lavf/56.40.101" 192.168.178.50 - - [27/Jun/2017:10:40:47 +0000] "POST /hls/test.m3u8 HTTP/1.1" 404 469 "-" "Lavf/56.40.101" 192.168.178.50 - - [27/Jun/2017:10:46:44 +0000] "POST /hls/test0.ts HTTP/1.1" 404 468 "-" "Lavf/56.40.101" 192.168.178.50 - - [27/Jun/2017:10:46:51 +0000] "POST /hls/test.m3u8 HTTP/1.1" 404 469 "-" "Lavf/56.40.101"
My web server is running apache2 on Ubuntu 16.04:Code:$ nmap -Pn -p 80 --script http-methods 192.168.178.100 Starting Nmap 7.01 ( https://nmap.org ) at 2017-06-27 10:47 UTC Nmap scan report for 192.168.178.100 Host is up (0.0015s latency). PORT STATE SERVICE 80/tcp open http | http-methods: |_ Supported Methods: GET HEAD POST OPTIONS Nmap done: 1 IP address (1 host up) scanned in 0.34 seconds
So according to the access.log file no matter what method I define in the ffmpeg command line it is always trying to upload the chunks using HTTP POST, but the latter is already supported and the directory I am directing the chunks has even 755 rights and is owned by www-data. What method FFMPEG is using to upload the chunks? Is it POST or PUSH/PUT. Is it possible somehow to figure out at least that?Code:$ apache2 -v Server version: Apache/2.4.18 (Ubuntu) Server built: 2017-06-26T11:58:04
Results 1 to 1 of 1
Download HLS video with FFMPEG
By capples3 in forum Video Streaming DownloadingReplies: 0Last Post: 29th Jan 2016, 16:37 -
Download HLS video using ffmpeg
By aliv in forum Video Streaming DownloadingReplies: 3Last Post: 11th Jun 2014, 18:52 -
HLS, HDS, DASH, RTMPT -- Adobe Air or Media Server or Other??
By quantass in forum Video Streaming DownloadingReplies: 2Last Post: 10th Feb 2014, 17:08 -
ffmpeg problems with HLS
By Pasarel in forum Video Streaming DownloadingReplies: 2Last Post: 9th Nov 2013, 20:50 -
Upload HLS content with HTTP PUT
By mazl in forum Video Streaming DownloadingReplies: 0Last Post: 13th May 2013, 05:08
