does anyone know where i can find a simple graphic editor?
graphic editor that
makes less than 1 or 2 sub directories and no more
doesnt leave many registries
doesnt windows come with the pbrush? i cant find this
Results 1 to 11 of 11
Windows 'Paint' is in 'Windows Accessories' in the main menu of W10.
If you want something a lot better, you could look here:
http://www.digitalcitizen.life/best-5-free-alternatives-microsofts-paint -
AA=http://www.digitalcitizen.life/best-5-free-alternatives-microsofts-paint
AA= seemed too big 100mb each. i am looking for maybe around 2m size, something simple for my XP. -
You might as well stick with Paint. There is probably no tiny third-party drawing package that will be easier to use.
I have more than one graphics editor installed. IrfanView (download for the latest version is 2.1 MB) is the smallest third-party graphics software I have tried, but its editing/drawing tools are no more advanced than XP's version of MS Paint. I'm not sure why I installed it anymore. Maybe to view and edit an animated GIF?Ignore list: hello_hello, tried, TechLord, Snoopy329 -
> IrfanView is the smallest third-party graphics software, but its editing/drawing tools are no more advanced than XP's MS Paint.
are you sure if IrfanView can let you edit? isnt it just a viewer? maybe a cutter a little. i tried IrfanView for the console cammands like below.
I_view32.exe"%1" /resize=(1080,1080) /aspectratio /jpgq=90 /convert=out.jpg occasionally until i replaced it with FFmpeg.exe few days ago. because irfan cant auto-find the minimum pivot value for w or h in resizing.
> MS Paint
i am not sure what i did with the MS Paint long ago, but it is still there in my OS for a default FAX viewer. but i can not run it independently, probably because i tried to uninistall a lot of things related with MS's bloaded softwares. you can say my XP is somewhat damaged but my XP is still fast and very stable. -
MSPaint in Windows is a .exe. It should be in the 'C:\WINDOWS\system32\mspaint.exe' You can also find it online.
I use the old Paint (XP version?) because I really dislike the new versions of it.
Since it's an executable file, no installation required. It's about 6.52 MB. -
when i opened up add/remove, to look fo a graphic editor reinstallation, it was not in the list. and i dont remember anymore if there ever was one in windows setup, another than "OPEN WITH.." then "windows pictures and fax viewer".
AA= "OPEN WITH.." then "windows pictures and fax viewer".
AA= seems to have a problem , if i accidently clicked on it, because it was so close to other openers in "windows shell", AA= was permanently but maybe {maybe because i dont want to verify this, it is not worth my time} hijacking other graphic extensions as in jpg, bmp.. etc then i had to reconfigure other openers again anad again... but maybe a little.
> IrfanView + Pressing F12
this can do, thanks and IrfanView is "windows shell" friendly and not greedy.Last edited by sommers; 27th Jun 2017 at 21:41.
> vectr
before installation, i watched the vectr review from youtube, it looked great, and it would be great for chemistry major people.
after i made OS mirror backup, and after the setup of preventing any file injections
i tried to install. but it only supported win10 based OS. not XP, so i will try this software some other time really later.Last edited by sommers; 28th Jun 2017 at 04:24.
I myself really like Paint.Net.
A little bit of a learning curve but once I figured out what I wanted to do, its 'a piece of cake' (I'm 70 yrs old/young)
I use it in conjuction with 'Graphics Workshop', <- thumbnails here & quick access to MSPaint.
Copy in any one & paste in any other.
(Graphics Workshop is $$, but worth it imo.)
-c-Yes, no, maybe, I don't know, Can you repeat the question?
Very Simple Video Editor
By mjgreer in forum Newbie / General discussionsReplies: 13Last Post: 22nd May 2016, 16:20 -
Simple tu use Audio Editor
By efiste2 in forum AudioReplies: 4Last Post: 12th Feb 2016, 03:54 -
New simple editor for critique
By Budman1 in forum Latest Video NewsReplies: 23Last Post: 3rd Oct 2014, 11:27 -
Simple editor advice
By lonepine in forum Newbie / General discussionsReplies: 3Last Post: 6th Feb 2014, 16:41 -
Simple A/V editor recommendations?
By danielmak in forum MacReplies: 0Last Post: 23rd Aug 2012, 03:24
