<retracted>Code:LoadPlugin("C:\DGDecode.dll") DGDecode_mpeg2source("src.d2v")
The flashing occurs on VirtualDub and MPC-HC previewing the .avs and in the encoded video. E.g. there is no flashing when using VirtualDub frame slider with mouse.
Entire video flash, every 2nd frame. The DVD source is fine and has no flashing.
What if you do Spline64Resize(720,312)? What if you delete Spline64Resize line? What if you delete crop line?
So MPEG2Source seems to misinterpret the content. Can you share a small trim of the video source? (Should be possible by selecting only few GOPs in DGIndex and exporting the video stream in this selection, or using MPEG2Schnitt or Cuttermaran.) I would suspect interlaced TransportStream with field oriented structure?
This supports my suspect: Misinterpretation due to flaws in the handling of a specific container/content combination.
How to delete flashing frames?
By jeffbiss in forum Video ConversionReplies: 7Last Post: 21st Jan 2016, 10:11 -
AntiVirus message keeps flashing
By shans in forum ComputerReplies: 8Last Post: 11th Aug 2015, 22:57 -
HDMI output to TV flickering / flashing
By planetrock in forum ComputerReplies: 6Last Post: 14th Jun 2015, 09:04 -
MPlayer last frame flashes green
By BobAchgill in forum Software PlayingReplies: 12Last Post: 10th Nov 2014, 11:53 -
flashing or blinking video
By piadex2 in forum Authoring (DVD)Replies: 9Last Post: 15th Nov 2013, 18:42
