Hello all,
I'm new to the forum and working with ffmpeg using windows machine so pls be gentle with me
My goal is quite simple, I have two video file, one is a clip from a GoPro camera and the other is a video produced by Filmora (video editor), I've tried, without success, to join the two files into one, I got errors trying the Concatenation of files with different codecs, from what i understand the files are not sharing the same codecs/res/and such and should be encoded, following is the ffmpeg -i output for both files(intro.mp4, GOPR2263.MP4:
Code:C:\ffmpeg-20170525-b946bd8-win64-static\bin>ffmpeg.exe -i intro.mp4 ffmpeg version N-86265-gb946bd8 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.1.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib libavutil 55. 63.100 / 55. 63.100 libavcodec 57. 96.101 / 57. 96.101 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 90.100 / 6. 90.100 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'intro.mp4': Metadata: major_brand : qt minor_version : 512 compatible_brands: qt encoder : Lavf55.33.100 Duration: 00:00:05.01, start: 0.000000, bitrate: 2476 kb/s Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 2213 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default) Metadata: handler_name : DataHandler encoder : libx264 Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 253 kb/s (default) Metadata: handler_name : DataHandler At least one output file must be specified C:\ffmpeg-20170525-b946bd8-win64-static\bin>ffmpeg.exe -i GOPR2263.mp4 ffmpeg version N-86265-gb946bd8 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.1.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib libavutil 55. 63.100 / 55. 63.100 libavcodec 57. 96.101 / 57. 96.101 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 90.100 / 6. 90.100 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 [mov,mp4,m4a,3gp,3g2,mj2 @ 0000000001ea24a0] Using non-standard frame rate 29/1 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'GOPR2263.mp4': Metadata: major_brand : mp41 minor_version : 538120216 compatible_brands: mp41 creation_time : 2017-06-25T12:46:31.000000Z firmware : HD4.02.05.00.00 Duration: 00:00:09.98, start: 0.000000, bitrate: 2087 kb/s Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709), 848x480 [SAR 1:1 DAR 53:30], 1954 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc (default) Metadata: creation_time : 2017-06-25T12:46:31.000000Z handler_name : GoPro AVC encoder : GoPro AVC encoder timecode : 13:12:09:24 Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 127 kb/s (default) Metadata: creation_time : 2017-06-25T12:46:31.000000Z handler_name : GoPro AAC timecode : 13:12:09:24 Stream #0:2(eng): Data: none (tmcd / 0x64636D74), 0 kb/s (default) Metadata: creation_time : 2017-06-25T12:46:31.000000Z handler_name : GoPro TCD timecode : 13:12:09:24 At least one output file must be specified
Can anyone please help me figured out the correct commands to join those two files?
Many thanks in advance!!
Best to all,
RS
Hi sneaker, thank you very much for your reply!
I've tried your suggestion but still no joy, I get the error "Conversion failed!":
your thoughts?Code:C:\ffmpeg-20170525-b946bd8-win64-static\bin>ffmpeg -y -i "intro.mp4" -i "GOPR2263.mp4" -filter_complex "[1:v]scale=1280:720[s];[0:v] [0:a] [s] [1:a] concat=n=2:v=1:a=1 [vid] [aud]" -map "[vid]" -map "[aud]" "output.mp4" ffmpeg version N-86265-gb946bd8 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.1.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib libavutil 55. 63.100 / 55. 63.100 libavcodec 57. 96.101 / 57. 96.101 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 90.100 / 6. 90.100 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'intro.mp4': Metadata: major_brand : qt minor_version : 512 compatible_brands: qt encoder : Lavf55.33.100 Duration: 00:00:05.01, start: 0.000000, bitrate: 2476 kb/s Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 2213 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default) Metadata: handler_name : DataHandler encoder : libx264 Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 253 kb/s (default) Metadata: handler_name : DataHandler [mov,mp4,m4a,3gp,3g2,mj2 @ 0000000000858c80] Using non-standard frame rate 29/1 Input #1, mov,mp4,m4a,3gp,3g2,mj2, from 'GOPR2263.mp4': Metadata: major_brand : mp41 minor_version : 538120216 compatible_brands: mp41 creation_time : 2017-06-25T12:46:31.000000Z firmware : HD4.02.05.00.00 Duration: 00:00:09.98, start: 0.000000, bitrate: 2087 kb/s Stream #1:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709), 848x480 [SAR 1:1 DAR 53:30], 1954 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc (default) Metadata: creation_time : 2017-06-25T12:46:31.000000Z handler_name : GoPro AVC encoder : GoPro AVC encoder timecode : 13:12:09:24 Stream #1:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 127 kb/s (default) Metadata: creation_time : 2017-06-25T12:46:31.000000Z handler_name : GoPro AAC timecode : 13:12:09:24 Stream #1:2(eng): Data: none (tmcd / 0x64636D74), 0 kb/s (default) Metadata: creation_time : 2017-06-25T12:46:31.000000Z handler_name : GoPro TCD timecode : 13:12:09:24 Stream mapping: Stream #0:0 (h264) -> concat:in0:v0 Stream #0:1 (aac) -> concat:in0:a0 Stream #1:0 (h264) -> scale Stream #1:1 (aac) -> concat:in1:a0 concat:out:v0 -> Stream #0:0 (libx264) concat:out:a0 -> Stream #0:1 (aac) Press [q] to stop, [?] for help [swscaler @ 00000000083d8ba0] deprecated pixel format used, make sure you did set range correctly [Parsed_concat_1 @ 0000000008313de0] Input link in1:v0 parameters (size 1280x720, SAR 159:160) do not match the corresponding output link in0:v0 parameters (1280x720, SAR 1:1) [Parsed_concat_1 @ 0000000008313de0] Failed to configure output pad on Parsed_concat_1 Error reinitializing filters! Failed to inject frame into filter network: Invalid argument Error while processing the decoded data for stream #0:0 Conversion failed! -
First file is limited range, second file is full range. I overlooked that.
Try:
ffmpeg -y -i "intro.mp4" -i "GOPR2263.mp4" -filter_complex "[1:v]scale=1280:720:in_range=full:out_range=tv[s];[0:v] [0:a] [s] [1:a] concat=n=2:v=1:a=1 [vid] [aud]" -map "[vid]" -map "[aud]" "output.mp4"
or if AR is different:
ffmpeg -y -i "intro.mp4" -i "GOPR2263.mp4" -filter_complex "[1:v]scale=1280:720:in_range=full:out_range=tv[s];[s]setsar=1:1[so];[0:v] [0:a] [so] [1:a] concat=n=2:v=1:a=1 [vid] [aud]" -map "[vid]" -map "[aud]" "output.mp4"
Joining 2 videos with different codecs and framerate
By mta3011 in forum EditingReplies: 4Last Post: 27th Jul 2015, 09:43 -
joining videos in Premiere CS5
By zoranb in forum EditingReplies: 7Last Post: 27th Aug 2014, 14:40 -
re-joining youtube segmented videos into one
By vhelp in forum ComputerReplies: 3Last Post: 13th Apr 2014, 18:34 -
Joining 2 .flv videos without re-encoding
By samus88 in forum EditingReplies: 2Last Post: 11th Oct 2013, 00:54 -
joining mp4 videos
By juodas in forum Video ConversionReplies: 2Last Post: 25th Mar 2013, 16:37
