Hi cats
I have 2 file, one MXF SD (IMX) colormatrix BT.601
and one MXF HD colormatri BT.709
If I use VLC to playback on the pc monitor this 2 files I see the colors of the SD one "correctly" meanwhile the colors of the HD seems a little "wrong".
I wonder if is there a way to see the HD ones correctly, thanks
[Attachment 42066 - Click to enlarge]
Try using the OpenGL renderer.
https://forum.videohelp.com/threads/384014-Why-only-Potplayer-has-that-color-problem?h...gl#post2489117Last edited by jagabo; 25th Jun 2017 at 09:47.
"Error opening mask file!.....[not] correct spool dir"
By Georgey in forum Newbie / General discussionsReplies: 6Last Post: 31st Dec 2022, 09:54 -
Correct deinterlace/IVTC settings for this PAL DVD ("Ikiru", Kurosawa 1952)
By abolibibelot in forum Video ConversionReplies: 17Last Post: 8th Oct 2015, 20:24 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
VLC player showing "undf"
By Pommy Paul in forum Software PlayingReplies: 4Last Post: 7th Jan 2014, 20:28 -
No suitable decoder module - VLC Error Message - "undf" - How to fix?
By newsunn in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2013, 18:57
